Hello from a striker owner
striker-euan - 30/10/13 at 10:49 AM
Hi
I thought I should say hi before asking (many) questions. I've recently bought a 4age 16v powered raw striker and stay near Edinburgh.
This is my first kit car and I didn't realise how much web browsing would be required as a kit car owner!
I'm finding this site is a great source of info.
Thanks.
Euan
RichardK - 30/10/13 at 11:32 AM
Welcome mate, you will find this a great site and probably all of your questions will have been asked over the years so don't forget the search feature.
Rich
pekwah1 - 30/10/13 at 11:35 AM
Welcome from another Striker owner (although mine's a Sylva).
I think the first thing you need to do is shower us with some lovely photos of your car!
You picked a good time of year to buy a kit car too!
bi22le - 30/10/13 at 04:50 PM
Hello from a fellow Striker owner, and 4age powered too. All be it a 20V version ;-)
Werner Van Loock - 30/10/13 at 06:31 PM
And hello from yet another 4age (16v) powered striker
As you can see, many striker owners present on this board.
This is how mine looks like:
Striker 2013
Striker 2013
striker-4age - 30/10/13 at 06:43 PM
Strikers are the best in my eyes
I own a 4-age 16v and a 20v with 272bhp !!!!!!!
steve m - 30/10/13 at 06:49 PM
Striker 2013
Striker 2013
Hi Werner
Nice wheels, were did you get them !!
regards
steve
R1_striker - 31/10/13 at 09:08 AM
i also have a striker, but with r1 power.
Best 7 type kit car on the market.
striker-euan - 1/11/13 at 09:53 PM
Thanks for the welcome. I'll get some photos.
It's good too see some more striker owners. Let the quizing begin ;-)
1) Is your engine parallel to the center-line of the car?
2) Is your diff solidly mounted to the chassis (for those with IRS)?
3) Any issues running 195/50/15 tyres with standard arches? Mine rub a bit on the outside of the rear arches, but there are also some marks showing it has rubbed on the inside at some point?
4) Anyone using a shortened sump? Any issues/recommendations?
The reason I ask 1 and 2 is that I've got a lot of drivetrain noise and Road and Race recommend I check out other sources of noise before resorting to sending the diff to them. One thing they said to check was that the propshaft output flange is parallel to the diff input flange.
Thanks for any answers/advice.
Euan
loggyboy - 1/11/13 at 11:09 PM
No , very much off centered due to the compact nature of the chassis.
Yes
Could be down to offset of wheel, rather than tyre size.
for a zetec, lots of guides on here, not sure about the toyota lumps, try a search on here or google.
props are usually best set so there is a slight angle.
[Edited on 1-11-13 by loggyboy]
bi22le - 2/11/13 at 08:27 AM
Almost deffinatly not.
Yup
My 185 rub so I shaved the arch a little. If you have a newish rear tube then it may be in 3sections. Raw can supply wider arches that just bolt on.
Not on my 4age. I dont ground out. The design is already quite good on the stock sump. I have an accusump so no starvashion concerns.
Describe the noise and somebody may be able to diagnose the issue. Whine while accelerating? Let off rattle?
Euan
BDMStriker - 2/11/13 at 05:41 PM
Welcome from yet another striker owner!
great car to work on too, enjoyed every minute,
Another Sylva build which is currently being rebuilt!
striker-euan - 3/11/13 at 08:19 PM
With any luck I'll have managed to post a photo here...
striker
striker
[Edited on 3/11/13 by striker-euan]
