Hi all,
Anyone know the headbolt sequence and torque setting for the Vauxhall Z12XE 1.2 Corsa C ?
Please don't say if the daft angle torque thing
I'm assuming it's start in the middle and work clockwise outwards.
Bet you have to torque then turn through 45% i'm sure that's what we had to do on the last Corsa we did a head on. The angle thing isnt a problem just make a circular cardboard disk and split into segment then align with a fixed point
Originally posted by NigeEss
Hi all,
i have them on my auto data handbook but i cant work out how to paste the screen shot up.....
stage one 25nm
stage 2,3and 4, 60 degrees...
It's the daft angle torque thing, sorry Have a look on Cavweb or corsa forum. I did my daughter's earlier this year but she took her book and I cant remember it offhand. The sequence is not what you said there it's middle then ends then all the bits in between. There are about 4 different stages to the tightening procedure. First stage was only about about 20lb ft, then 90*, 90*, 90* then 30* but that's just an example not the actual figures
Thanks all,
double thanks Boggle
some other torque settings you may find usefull.....
