O/T: How do I fix this bath panel
James - 4/9/15 at 08:45 PM
Greetings all,
How do I fix the bottom side of this bath panel?
[img] Bath panel
Bath panel
[/img]
The top has a flange that tucks up inside the lip of the bath. The bottom however... I could put some sort of batten on the floor and screw through but the panel is curved so it'll distort the panel and there'll be visible screws (with covers).
I suppose I could screw downwards into the floor through the return, but only at the one end of the bath!
My other idea is some sort of batten with a rebate cut into the bottom/outer corner and the bath panel return 'tucks' under it... but how will that fix?
There must be a better way that allows it to be removed for maintenance etc.
Help!
Thanks!
James
mcerd1 - 4/9/15 at 08:55 PM
easiest way I can think of is to screw an alloy channel to the floor for it to sit in
you'd see it but it would just look like a bit of trim that would match things like the shower screen etc... (or you can always paint it white if need be)
[Edited on 4/9/2015 by mcerd1]
chris - 4/9/15 at 09:10 PM
fitting those plastic panels are like trying to wrestle an aligaitor cant beat a wooden panel
ste - 4/9/15 at 09:11 PM
Mine is attached with screws and white caps to a batten on the floor under the bath
cliftyhanger - 4/9/15 at 09:16 PM
A bead of silicone to seal it to the floor. After all, how often do you delve under a bath?
Edit and I stick a batten to the floor behind, again with silicone.
[Edited on 4/9/15 by cliftyhanger]
MikeR - 4/9/15 at 09:33 PM
Batten behind the panel and painted batten (skirting board) infront and screwed through to batten at rear.
owelly - 4/9/15 at 09:36 PM
Screw a batten to the floor but space it off the deck so the lip of the panel slides under the batten. Then use silicon to clag it on, or Velcro.
gremlin1234 - 4/9/15 at 09:38 PM
hook and loop tape (Velcro) on the inside of the panel, and on a baton behind
Irony - 4/9/15 at 09:40 PM
I pushed my bath panel into position and tucked it up into inside of the bath moulding. I then wedged some 2x1 timber underneath the Bath panel. I trimmed the 2x1 until it was a tight fit and then stained it to match the panel. I then used silicone to seal the lot. If the thing is sufficiently snug the silicone will hold it.
loggyboy - 4/9/15 at 09:49 PM
Our FG bath panel came with clips that screw to a batten or wall and pinch the edge of the panel.
craig1410 - 4/9/15 at 11:28 PM
I worked some magic on my bath with some magnetic fasteners I got from B&Q.
cliftyhanger - 5/9/15 at 07:39 AM
Been thinking!
This bath panel malarky is always a faff. I always have to cut panels down when retro fitting, and then all this stuff having to attach them.
I think there is room for a attaching system in the market! Get on Dragons Den and make a fortune.....
theprisioner - 5/9/15 at 08:37 AM
I have tried to fit many of these and never achieved it without a baton on the floor type approach. The regular fitters of these use silicone (vasy quantities) . They are c..p, the ones that work best mechanically are wooden but don't last. I have used t&g either wood (treated) or uPVC (which is water proof) to great effect. (9 years as an odd job man).
coyoteboy - 5/9/15 at 10:31 AM
Use bath panel as template for curve, router curve into batten, screw batten down, screw panel to batten, caps on screws.?
jacko - 5/9/15 at 06:26 PM
My b&q bath came with clips you screw to the floor and the lip on the side slides into them
jacko
Hodor - 5/9/15 at 10:59 PM
I threw the plastic panel away and fitted some MDF and tiled it the same as the bathroom walls. Never getting back under the bath, but looks good.
theprisioner - 6/9/15 at 06:20 PM
Right decision in my book.
mcerd1 - 7/9/15 at 07:28 AM
Mine is tiled onto ply, but with a removable panel to get to the drain / taps
The removable bit is held on with screws through the tiles (with some covers to make them look better) its sized to match the tiles and its got silicone instead of grout around it
Bit of a faf to make but it means I should only need to redo the silicone if I need under the bath...
