Work shop build, started
b14wrc - 15/10/18 at 06:56 PM
Well we moved house last September and left behind my old garage I had spent a long time isulating and boarding out to start my locost. So I'm back to square 1 as my garage is a single course concrete block construction, the good point it is 6x6m. So is twice the size of my old one and now we have the drive way sorted, I've turned my attention to the work shop.
Gathered materials over past few weeks and this weekend finished work Thursday to have a long weekend at it, partner and kids away for a week so I used my time wisely. Doesn't look like I've achieved that much, but there was a lot of wiring to remove and as I have no storage yet I have to move stuff around. Anyway you get a good idea of what I'm doing:
Basically foil lined vapour barrier direct to the brick, 100mm of battens at 600mm centres, then another layer of foil, I've foil taped all the joints, the whole garage is getting that treatment with new double glazed windows on the other side. I am going to run conduit (16mm deep) where I need it then 12.5mm plasterboard to finish, 9 on the ceiling. Lot of work to do, but stage 1 is to complete the above on the whole garage, phase 2 is to board, skim and wire (include LED lighting) then phase 3 will be to build the work benches and stowage, seen a ikea kitchen I want. I'm going to integrate a beer fridge. Will be good when finished. Entertainment and wood burner will be stage 4...... going to install a projector along with a high powered sound system. It will be a decent man cave / work shop. Then I might finally get the car finished lol, my partner said today next you will be tiling the floor.... the thought had crossed my mind actually.
More to come.
Rob
big_wasa - 15/10/18 at 07:17 PM
Don’t forget a dish washer next to the fridge for them oily engine parts.
b14wrc - 15/10/18 at 07:54 PM
Yes got one, that's what the blue pipe is for, supplying cold water to the sink and dish washer.
Mr Whippy - 16/10/18 at 11:35 AM
I see where this is going....
You will be watching films, drinking beer rather than working on the car and it will end up holding up a pool table...
trextr7monkey - 17/10/18 at 12:16 AM
2 ovens - one for pies and one for powder coating. Should be snug in there if you stop all the drafts. Is girder for a hoist too?
Atb
Mikew
b14wrc - 17/10/18 at 11:26 AM
To be honest its pretty dry and draft free as it was, its really only the door that lets in a draft. I am going to add brushes to the door eventually.
Yes,, the girder is for a full width lifting crane, I need a decent block and tackle but it will work a treat if I need to lift the car off the table or put the engine in. I will be posting photos when I go anyway, have a bit of a build blog. The main thing is I have a plan of what is needed, the past year I have just been messing around in there....!
nick205 - 17/10/18 at 01:21 PM
Nice - nothing like a comfy place to work in the evenings and weekends.
The steel beam certainly looks handy for lifting too.
AlexXtreme - 18/10/18 at 12:52 PM
Looks good and I should do the same! What are you doing about the damp course and avoiding any bridging?
b14wrc - 21/10/18 at 04:26 PM
Hadn't really thought about the damp course, I think the membrane should hold it back, but to be honest it's a pretty dry garage, even on a wet weekend like this!
b14wrc - 21/10/18 at 04:30 PM
I've started the next wall, hoping to get it insulated and installed next week, it's free standing so he garage door slides "open" behind it, will allow me to fix cupboards above my lathe and use the space more efficiently.
I'll be thickening up all the frames, that should take the cupboards.
Rob
[Edited on 21/10/18 by b14wrc]
b14wrc - 22/10/18 at 09:00 PM
That's almost the finished frame, going to fix to floor, above the door slide and side wall, should be study enough to support cupboards, I know I've lost 210mm of space, but once insulated, the space will be much more usable, I'll run some decent lighting for the lathe and there won't be worries of things snagging on the door when I come to open it, that's the main problem now, things tend to go behind the lathe and roll cab and get in the way of the door. Some decent seal brushes should keep the drafts out.
Plan to insulate the back of the door too, but I'll keep it light weight I think and pretty low profile to minimise the amount of space the wall needs to allow.
Thursday I plan to get that finished and start the back wall. Pretty decent rate at the moment, few hours here and there seems to make a difference.
Rob
b14wrc - 28/10/18 at 11:53 AM
Had a good week off for my birthday and managed nearly two full days working on the garage, progress, starting to get there, going to be hard to keep the pace up with a young family, but I'm not in a rush really.
Got the lathe positioned where I want it and that wall is structural enough now to take the cupboards I'm fitting above the lathe.
Now to start insulating the next wall..... bit of a mess!
So now I need to think about new widows and complete the final two walls, the roof is going to be a bit tricky.
There is a car under all that mess! Lol.
Rob
b14wrc - 17/11/18 at 08:10 PM
Update on the door:
trextr7monkey - 18/11/18 at 10:32 AM
That’s looking really good you seem to have enough space to move stuff about while working. I have a double garage under the house built on Bison beams and could do with adding sound insulation and a plaster board ceiling and it’s so full of stuff that it’s a struggle knowing where to start!
Look forward to seeing it finished
b14wrc - 18/11/18 at 11:02 AM
Thanks.
b14wrc - 25/12/18 at 02:46 AM
Had a few hours Friday night and got this done, happy Christmas!
[IMG]http://i112[URL=http://s1126.photobucket.com/us er/b14wrc/media/E4B05C50-F1F3-46A0-841F-017482DFC4A0.jpg.html]
[URL=http://s1126.photobucket.com/user/b14wrc/media/05CD6390-86DC-479F-BB60-C390186386B3.jpg.html]
Hoping to get a bit more done over the Christmas holiday. Rob
trextr7monkey - 25/12/18 at 11:48 AM
Great progress- could be driving that car this time next year😁!!
b14wrc - 28/12/18 at 06:23 PM
Lol, it's getting there.
b14wrc - 28/12/18 at 06:32 PM
Got some Solar power fitted on the garage roof, powers the house and get paid from the government.
Looking sweet, if the Locost takes any longer to build I might have to convert it to electric and use the solar to charge it up!
Rob
samjc - 29/12/18 at 02:50 PM
Nice job, in the process of doing mine, did you do the solar system yourself ? Id battery back up first before feeding the grid as the return is rubbish.
Regards
Sam
b14wrc - 30/12/18 at 11:53 AM
I didn't fit the solar myself, it was installed for me but it is hocked up to the house. Reason I got it was to save money on my energy bills, we have oil too, and the price of that is always going up. The returns are not as good as they were a few years ago, but the system should bring me an average of 10% ROI. Will see anyway.
Yes, I've looked into a battery, thinking I might do that in a year or so, once I've seen what I'm making. The system is 4KW, and considering the time of year and the weather we have been having is generating a good amount. Since the system was fitted, about 6/7 weeks ago it's generated around 90kWh.
Hoping to get back to the garage build later today. So expect some more updates.
Rob
b14wrc - 14/1/19 at 08:52 PM
So as a little side project, I wanted to build a new build table, one with wheels so I could use my new work shop more flexibly once it’s all finished in the summer. The under tray will be used to stow my grey plastic boxes.
It still needs work but it’s getting there. Hoping next weekend to finish it and get the final wall sorted. Means my focus can turn to ordering my new double glazing. That should really start to change things!
Rob
b14wrc - 16/2/19 at 11:09 AM
So I finally fitted my new windows yesterday, big improvement!
Next job is to put a new hole in the wall for the stove as I don’t want to use the one already in the roof, and I need to finish the window reveals on the outside, pebble dashed.
The next phase of the garage is to do the insulating in the roof, shouldn’t take too much time. I am building a shed in a few months, that will relieve some of the space constraints I have in the garage which will be a big help when the plaster board arrives. Hoping to get it all finished this summer so I can get back to the car in full next year. Maybe get it finished!
Rob
b14wrc - 30/3/19 at 11:11 AM
So a little update, the farmer was upset with my new windows- apparently he doesn’t like the fact I can now see out. So I’ve fixed that with window tints, he complained he didn’t want to see me looking out, so now he can’t.
Also finished the stove, just need some more paint and do the flu brackets.
Rob
trextr7monkey - 30/3/19 at 12:00 PM
That garage is like the Tardis! 😂 External pics looks like a normal size then interior pics reveal a load of space, looks like you are nearly there now.
Atb
Mike
b14wrc - 30/3/19 at 07:53 PM
Thanks Mike, it’s a decent size, 6x6, obviously bigger is always desirable, but I have enough space to build the workshop. Been fancying a new daily driver, Lamborghini Gallardo, If I go that way I might consider putting it in the garage with the locost, but will have to see.
hobbsy - 30/3/19 at 10:53 PM
Who says there aren't well paid jobs "Up North"
Loving the garage build, jealous as I went from double garage with car port with inspection pit to a much older house with an outbuilding that is a fraction smaller than a single garage
Having to be super inventive with the space...
b14wrc - 14/4/19 at 08:25 PM
Some updates from this weekend, hope to get another day over Easter, the plan being complete the insulation within another month. Been working on making a round window frame to fit above the door, it will act as a port hole light, put some photos up when it’s done.
Around the beam has been left as I need to get in to paint it. I am thinking of anthracite coloured cupboard doors against white walls, and I fancy a strip of the Italian flag across the middle, was thinking a vinyl strip. My friend is going to help me paint a Muriel on the back of the garage door, it will include the outline of the Nurburgring and some Italian details, as my car is Fiat coupe 20vt it will include something regarding this, I was born in October so I like the Abarth Scorpion. This will be the badge for the locost eventually.
Need to start building a shed I have planned, weather is getting better so need to get that done to make space for the plaster board arriving, think I need 24 full sheets.
Rob
b14wrc - 12/5/19 at 12:40 PM
Been getting on past few weeks. Designed and made this window:
Installed and painted in primer:
Nice little feature for the workshop I thought.
b14wrc - 13/5/19 at 08:54 PM
Some weekend relaxing.
Ronski - 5/7/19 at 06:24 PM
That garage is very nice, looks rural as well so noise shouldn't be an issue although all that insulation and extra stud wall will act as soundproofing. As for the farmer not liking you looking out makes me wonder what he's got to hide
Get yourself a motorised winch, both for lifting and moving along the beam, we have one at work, dual speeds, absolutely brilliant and so much easier if your on your own - I manoeuvred a truck engine in yesterday on my own.
As for the cinema bit, this is mine, which I built.
b14wrc - 5/7/19 at 07:02 PM
I checked the link to your cinema build, nice I know a few who have done similar, my brother converted his garage recently, it’s so much better than just a tv! Good work.
I’ve had a pretty busy week, got friends coming tomorrow but I’ll try and get out into the garage Sunday and get you some measurements, I have an engine and box on a pallet, if you need the hub to hub dim my drive shafts are packed away at the moment, but I probably have the track written down some where and could work it out, your mini looks really good. Look forward to seeing it progress, especially with a 20vt!
Rob
Ronski - 5/7/19 at 08:15 PM
Thanks, no need for the track width, I'd alter that to suit the Mini, I had drive shafts made in the early 90's and with some luck they may fit the 20vt.
b14wrc - 5/7/19 at 09:43 PM
Nice one. Happy to help if I can.
b14wrc - 19/7/20 at 11:09 PM
Wow, it’s been nearly a year since I last posted progress on my workshop build. It’s getting there but still not finished. Planning on getting set up end of this year to carry on the build next year. So for now, some progress shots just to bring the post up to date, detail to follow:
Rob
MikeR - 19/7/20 at 11:26 PM
Looks fab, bet it's never that tidy again
b14wrc - 26/7/20 at 08:29 AM
Oh I’ll be keeping it tidy!
Started building my 3D printer cabinet, should keep it clean and insulated.
And another shot of the locost motor back in the car, first time in 3 years!
b14wrc - 26/7/20 at 01:22 PM
And I did get a chain block in the end. Very useful!
Rob
b14wrc - 1/8/20 at 12:26 PM
Well yesterday ended up a bit of a right off in terms of progress, I finished working later than I wanted and cut the grass as the sun was out. By the time I’d sat down ready to think about a session in the work shop it was already 7, so I cracked open a cider had a bbq and decided to just chill instead.
I got my PS3 hooked up to my projector and watched a few you tube videos in the workshop, still need a load of wiring and a bracket for the projector but for a cheap projector I was pretty impressed! Will be better once the walls painted white but you get the idea, 3m wide screen is pretty decent.
Was watching Audi videos...
The line is the trunking, it’s actually going to be projected on the back wall eventually, there isn’t trunking deliberately on that section.
b14wrc - 10/10/20 at 01:52 PM
Electrics finished last night. Good feeling being able to plug every thing in properly now with a choice of over 10 different sockets to choose from. Pure luxury considering I had 1 available socket and had to stitch the extension in every time I wanted to do anything.
Beer fridge is now cold.
And I wired in a little mood lighting..... in my 3D printer cabinet.
Can have it any colour. It’s pretty trick.
b14wrc - 9/1/21 at 07:34 PM
Christmas paint....
First coat of under coat gone on, makes a massive difference.
Rob
