Which zetec cam?
novacaine - 20/4/09 at 09:26 PM
Hi all,
After being confused by the burton power website I'm after some recomendations for a cam for a 2.0 silvertop
I'm happy to put up with a lumpy idle to get a good high performance cam
Do cam kits generally come with springs?
Matt
zetec - 20/4/09 at 09:36 PM
Cams dont normally come with springs. You need to decide if you want to change pistons and valve train. If you don't then Piper 285 is normally the way to go...it should be fine using all standard parts if rev limit is kept below about 7300 and will give about 200 bhp, just check piston clearance before firing up. Cam choice will be dependent on whether you want to port the head, if not going for anything too wild will be a waste. Also you don't mention what fuel system you have.
austin man - 20/4/09 at 09:37 PM
doesnt your zetec have hydraulic lifters ??
novacaine - 20/4/09 at 09:59 PM
Will be running it on megasquirt and bike throttle bodies, 200-220 would be my target, maybe more depending on cost
I don't really want to get into changing pistons but I might get the head ported, again depending on cost
Thanks for the replies
Matt
catman - 21/4/09 at 09:54 AM
ive got some Fz2001's for sale with matching followers, these are good for 195bhp on a properly sorted engine,cost over £400 new, im after £190
Ed
