Zetec Weight Vs Duratech Weight.
dhutch - 30/4/10 at 09:40 PM
I was just wondering if anyone had ever weighed a zetec against a duratech.
IM sure someone has, but ive never really seen figures side by side.
Clearly the duratech is aluminum, but the block is a small part of the engine weight and theres a fair bit of it in the duratech.
Just wondering. Not planning to go duratech, but curious.
Daniel
scootz - 30/4/10 at 09:45 PM
2.0 Ford Zetec is about 125kg.
2.0 Ford Duratec is about 105kg.
Both weights with ancillaries.
mangogrooveworkshop - 30/4/10 at 09:59 PM
scott
Was that how much you payed for them or how they weighed in at
scootz - 30/4/10 at 10:10 PM
The hint is in the KG's!!!
bi22le - 30/4/10 at 11:43 PM
any body know the weight of a 1.6 4age 20v? I know its a cast block so will weigh more than there two. But as the post is already up. . . .
Thanks for the reply
oldtimer - 1/5/10 at 06:48 AM
I think the 4age is 80kg bare.
coozer - 1/5/10 at 06:59 AM
While we're her, anyone know the weight of a T16 turbo engine??
graememk - 1/5/10 at 07:06 AM
can you quess how much i weigh ?
coozer - 1/5/10 at 07:11 AM
125kg?
iank - 1/5/10 at 08:36 AM
From what I remember (think PPC did a bit on the t16) is it's a shared block between petrol and diesel engines and is very heavy.
iank - 1/5/10 at 08:40 AM
I've read (can't remember where - sorry) that some modern cast iron blocks are very similar in weight to (probably older design) aluminium blocks due to minimising the amount of metal - only possible with cad design and spending time doing lots of stress calcs.
I think the 4age was brought out as being very light for an iron block engine.
britishtrident - 1/5/10 at 09:06 AM
A little bit heavier than an MGB 1800 B series engine which is heavier than a 2 litre Pinto
mid-buggy - 1/5/10 at 09:13 AM
I have an a-series (hence wanting to jump to BEC) bet that weighs more!
dhutch - 1/5/10 at 10:43 AM
Sounds fair enough.
- I guess thats 20kg or 20% saving so not nothing.
spiderman01980 - 2/5/10 at 07:40 PM
try this westfield site it might help!!
http://westfield-world.com/enginespecs_car.html
beaver34 - 2/5/10 at 07:46 PM
a good site,
quite a wide weigh differnce between engines,
nice to know i have the lightest in my car haha
spiderman01980 - 2/5/10 at 07:57 PM
a good site,
also try this bit of the site, its a Power to Weight Ratio Calculator
http://westfield-world.com/power-to-weight.html
