Engine cleaning 'bath'
johnH20 - 6/2/12 at 03:35 PM
Been searching 'engine cleaning'. Lots of advice on products to use but none on dealing with the mess! I have been thinking along the lines of some kind of industrial tray with 15 - 20 cm deep sides which will catch most of the run off and placing this on a large tarpaulin to catch the inevitable splashes. Any ideas on what might be suitable and where to get it? It needs to be locost of course! TIA.
Bluemoon - 6/2/12 at 03:44 PM
Old bath from skip.. Even has a drain hole... On mine just hung from engine crane with a tray underneath and sprayed with air parifine gun to clean up (didn't want to paint just get of the crude collected by fords best oil leaks (or active rust control system??)..
Dan
designer - 6/2/12 at 03:54 PM
Pressure washer, but even better: steam clean. If you have to hire it's worth every penny.
ashg - 6/2/12 at 04:03 PM
diesel powered steam cleaner down the bottom of the garden with a healthy dose of traffic film remover solution.
nick205 - 6/2/12 at 04:12 PM
Might sound daft, but a kids paddling pool costs less than a tenner and if you stand the engine on some bits off wood the pool won't rip. Once your done simply pick the pool up, cut a hole in the the bottom, drain into a suitable container and dispose of appropriately.
jabbahutt - 6/2/12 at 04:28 PM
Nick where were these amazing tips when I wan sorting my engine and getting grief from the wife for making a mess of the drive
Chippy - 6/2/12 at 04:50 PM
Four bits of 2" x 2" timber formed into a square, just nail together, then cover with a piece of thick polythene sheet, makes its own tray. Cheep as chips and works a treat. HTH Ray
chris-g - 6/2/12 at 05:26 PM
Cement mixing tray from Wickes or B&Q.
http://www.diy.com/nav/fix/handtools-storage-workwear/handtools/plastering-decorating/paint_trays/Active-Products-Multi-Purpose-Mixing-Tray-9273112 />
http://www.wickes.co.uk/invt/543009
steve m - 6/2/12 at 06:16 PM
i bought a 24" x 24" plant seeding tray, the sides are about 4", twas £10 in asda about 5 years ago
doubles up as a handy oil catch tray on oil changes as well, as i ALLWAYS make a mess!
I cant use it as a drip tray on the 7, as the sump is only 3.5" from the ground
coyoteboy - 6/2/12 at 07:44 PM
I'm cleaning my block with a toothbrush and cloths, not dropping anything on the garage floor yet!
johnH20 - 6/2/12 at 09:34 PM
Brilliant ideas here, thank you all. As it happens I ( the Mrs ) am having a bathroom redone so I am about to inherit a bath. Perfect!
