2006 r1 hot oil pressure
charlie_pank - 31/3/12 at 09:47 PM
Anyone know what I should expect to see? I'm getting around 80-90psi at 8000 rpm. Seems v. high to me.
Smigga - 31/3/12 at 09:53 PM
Dont know if it relates but my Blade runs similar...
Dave
adithorp - 31/3/12 at 10:40 PM
Sounds about right. How hot was it? Mine makes about 10psi/1000rpm @80c. It's very low at idle (hardly lifts the gauge) when hot but about 60psi when cold. It's low idle pressure that worries most people.
charlie_pank - 1/4/12 at 06:22 AM
I'm ok with the idle pressure of 10-20 psi @80degrees C, I was more alarmed by the pressure going up to over 90 when pressing on!
kjouk - 1/4/12 at 08:28 AM
The pressure relief valve is spec'd at 87-99 psi so within normal range of that. The service manual test is 33psi @ 5000rpm with 80-90C oil temp.
charlie_pank - 1/4/12 at 01:43 PM
I reckon my OPG might just over-read a little. As you say the Haynes manual states an opening pressure of up to 99psi
MK9R - 1/4/12 at 03:25 PM
That sounds ok to me, similiar to mine.
