Wrong Type 9
lsdweb - 17/8/15 at 08:30 AM
Hi All
I have the wrong type Type 9 gearbox for my Striker - I need the longer input shaft version to work with my Caterham bellhousing and K series. I was planning on using the Type 9 as is but that doesn't now seem to be an option.
I'm trying to make up my mind on what to do! Any thoughts on the following options -
1. Swap the input shafts (I have no idea if this is possible and the last time I delved into a gearbox it wasn't a pleasant experience!).
2. Find a second hand long input shaft box (Capri , XR4?)
3. Buy an uprated box with longer shaft (an uprated box was part of a longer term plan).
4. Sell the Dave Andrews built short stroke 1400 K series and go BEC :-)
Any views appreciated!
Ta
Wyn
liam.mccaffrey - 17/8/15 at 08:40 AM
I don't like number 4
jambojeef - 17/8/15 at 08:51 AM
Uprated box.
That engine in a nice light 7 should be a hoot!
Geoff
Paul Turner - 17/8/15 at 08:56 AM
Option 5. Speak to Steve Perks in Redditch. 01527 894232. He will sort out your existing gearbox with a long input shaft and for a small extra sum fit a better first gear. All for a fraction of the cost of a BGH or similar.
lsdweb - 17/8/15 at 09:55 AM
Thanks all
I'll give Steve Perks a ring today.
Ta
Wyn
scootz - 17/8/15 at 10:06 AM
5. Get a Caterham 6-Speed Box
6. Get a Caterham 6-Speed Box
7. Get a Caterham 6-Speed Box
8. Get a Caterham 6-Speed Box
9. Get a Caterham 6-Speed Box
10. Get a Caterham 6-Speed Box
11. Get a Caterham 6-Speed Box
12. Get a Caterham 6-Speed Box
13. Get a Caterham 6-Speed Box
14. Get a Caterham 6-Speed Box
15. ...
lsdweb - 17/8/15 at 10:59 AM
15. ...
I don't suppose you have one....
femster87 - 17/8/15 at 12:36 PM
I love option 4 1st dibs for £500
lsdweb - 17/8/15 at 12:38 PM
Add a zero on the end and it's yours!
Ugg10 - 17/8/15 at 01:04 PM
What about the RX8 option that the classic ford boys seem to be using at the moment, forget 1st gear and you then have a close ration 5 speed box. Just needs an adaptor plate, input shaft spline and spigot bearing are ford compatible.
lsdweb - 17/8/15 at 01:10 PM
Thanks Ugg
I did think of that but the tunnel is too small for it I believe.
scootz - 17/8/15 at 02:51 PM
Sorry - no Cat box.
adithorp - 17/8/15 at 03:20 PM
It'd be a shame to give up on the K-series but... "Go BEC" is always the correct answer.
I'd have sworn Scootz had one when he said that.
snapper - 17/8/15 at 05:44 PM
Sierra V6 engined cars have the long input Type 9
Ratios are better
V6. Straight 4
1st 3.36. 3.6
2nd 1.81. 1.97
3rd 1.26. 1.36
4th. 1. 1
5th 0.85. 0.87
Ugg10 - 17/8/15 at 06:10 PM
Thanks Ugg
Lots of pics and comparisons with type 9 in this thread if you need to check sizes.
http://www.turbosport.co.uk/showthread.php?t=500016
Paul Turner - 17/8/15 at 07:03 PM
Ratios are better
V6. Straight 4
1st 3.36. 3.6
2nd 1.81. 1.97
3rd 1.26. 1.36
4th. 1. 1
5th 0.85. 0.87
Both the 4 cylinder and V6 box have a 0.82 5th as standard. The 0.85 and 0.87 are the ratio's you get form BGH, Quaiffe and others.
matty h - 17/8/15 at 08:23 PM
I will hopefuly be doing this match up of engine and gearbox soon including caterham bellhousing, although I am seriously looking at rx8 box probably 5 speed as it seems to have more useable 1st gear over the more expensive 6 speed.
Can a adaptor not be machined up to fit on the end of the shaft and welded on.
Matty
dilley - 17/8/15 at 08:51 PM
And the rest!!!! S2000 with gear indicator is 8k!!!!
lsdweb - 17/8/15 at 08:55 PM
Shortstroke Rover K Series.......
[Edited on 17/8/15 by lsdweb]
lsdweb - 17/8/15 at 09:07 PM
Matty
Is the five speed similar to the six? Does it have the same splines etc to match up with the Ford clutch?
Ta
Wyn
femster87 - 17/8/15 at 09:16 PM
Wyn, the input shaft can be changed, had similar done for my K series installation. Would have loved your engine bought a 1.8 few months ago.
I will change the ratio whilst you are at it though. I bought a locost with a standard type 9, I have to say after years of having either a straight cut close ratio and the 6 speed gearbox, the standard box feels really odd and sluggish
[Edited on 17/8/15 by femster87]
lsdweb - 18/8/15 at 08:09 AM
Thanks Femi
I'd love to go for a proper competition 'box but can't justify it right now!
I've just bought an RX8 gearbox to see if it'll fit in the tunnel - I don't think it will but I'll give it a go just to satisfy my curiosity!
Regards
Wyn
COREdevelopments - 21/8/15 at 09:49 PM
Hey Wyn, sorry can't help with your query but out of interest how wide is your transmission tunnel? Is it similar locost book chassis? I am looking at a different gearbox due to a problem with my ae86 t50 box.
Thanks Rob
lsdweb - 27/8/15 at 10:38 AM
Hi Rob
Sorry for the delay in replying - we've just got back from holidays.
The box is way too big! The tunnel on the Striker is tiny and the box is over an inch wider at a point just in front of the gear lever. I can take some measurements if you want. You're more than welcome to borrow the Mazda gearbox to try in your Luego.
Regards
Wyn
rdodger - 27/8/15 at 05:28 PM
15. ...
This!
snapper - 28/8/15 at 03:19 AM
The best option is to buy a Type 9 from a V6 Sierra or Cologne engine Capri and fit the longer 1st gear
V6 Type 9 ratios are better than the straight 4 variant and some of the stronger V6 box come with a larger layshaft bearing
got this info from sierra owners club.
the way i understand it, it should give better acceleration.
and has heavy duty bearings
[Type 9 (1.3-2.3)
1st 3.65
2nd 1.97
3rd 1.37
4th 1
5th 0.82
Type 9 (2.8 inc 4x4 )
1st 3.36
2nd 1.81 (this is the ratio that lets the 2.8 go over 60 in 2nd )
3rd 1.26
4th 1
5th 0.825
COREdevelopments - 6/9/15 at 06:21 PM
Thanks for the reply Wyn. I may take you up on that offer. Will let you know in advance if that's ok?
Rob
