Ignition connundrum
bumpy - 28/1/16 at 03:02 PM
I have a long standing issue with the ignition timing on my 2 litre Pinto engine which I am inspired to cure as soon as I get on the road this Spring.
In short
The engine is totally standard in all respects - Weber carb, standard exhaust, standard camshaft etc etc
If I set the timing according to the book (say 8-10 degrees), it starts fine but seems like I only have a 500cc engine on board, completely gutless.
If I stop during my ride and advance the ignition timing incrementally up to say 15 - 18 degrees BTDC, the power gradually comes in and it becomes a nice energetic engine. There is no great evidence of pinking, but in an open top car its generally less easy to hear. The engine stops and starts without drama.
I park up happily for the night, but next morning the car refuses to turn over to start. I can sense the pistons coming to the top of their stroke and being pushed back. For me this is displaying all the symptoms of an ignition that is too far advanced . When I retard the ignition again it starts fine, but the cycle begins again.
The battery takes a good charge and shows the normal voltage of a good battery. The ignition is measured using a powered timing light and with vacuum detached.
Any guidance would be welcomed.
nick205 - 28/1/16 at 03:12 PM
When you say the engine is standard, is it using all the same parts as when in the donor car?
I put a 2.0 Pinto in my MK Indy a few years ago and had to change from a Ford to Weber carb. In getting the car running right I took it to a rolling road and the Weber carb had to be re-jetted to deliver fuel correctly through the rev range - it made quite a difference to the way the car drove and may be worth checking on your engine/carb.
gremlin1234 - 28/1/16 at 03:22 PM
distributors usually have weights in to give a mechanical 'advance'
my guess is these have seized, or the springs broken.
striping and rebuilding a mechanical distributer is not too difficult
see also
https://en.wikipedia.org/wiki/Ignition_timing
edit sp.
[Edited on 28/1/16 by gremlin1234]
FuryRebuild - 28/1/16 at 03:37 PM
It does sound like the dizzy
Pintos like advance. On my race engine, I was running up to 32 degrees, and it was a pig to start but ran like a beast. Then I moved over to an MSD 6A ignition which retards the ignition 20 degrees on startup, and it started marvellously every time.
I threw the chokes away, and it would light up first turn of the crank. It was on a pair of twin 45 dellortos which are pretty reliable. They were properly setup, choked and jetted by bogg-brothers.
bumpy - 28/1/16 at 03:46 PM
Thanks so far guys. I have been fettling with this engine for quite a while, so have already covered a fair bit of ground.
The engine is as taken out of the donor car.
The carb has been stripped and all jets marry up to the book values.
The bob weights are free and the vacuum advance works fine, indeed I substituted in another distributor and that gave exactly the same characteristics. but, I will strip and investigate both.
To FuryRebuild.
That 32 deg timing, was that set at tickover or at elevated revs. I will have a read up about the MSD 6A ignition system.
mcerd1 - 28/1/16 at 03:51 PM
This might sound stupid, but have you verified that TDC is where you think it is ?
Which type of crank pulley have you got?
What kind of coil have you got ? (9v or 12v)
Also were abouts in the country are you?
[Edited on 28/1/2016 by mcerd1]
FuryRebuild - 28/1/16 at 03:53 PM
The 32 degrees was set at full chat and load - you want it accurate when you want the power. I think it was timed at about 4800 RPM when my cams came fully on (stage 3 tarmac). The timing is a combination of carb setup (new jets and chokes), cam requirements, valves (I had wahoosive valves in there), fuel quality (optimal and Aldon) and tractability. I could get away with a really hairy cam because my car was relatively light - it was still drivable around town in much the same way as an RS2000 wouldn't be.
The MSD also gives a massive belt of a spark, which contributes to it. You need more spark to light up a high-compression mixture. You can open the plugs a little wider to get a better burn. It's all a closed system that sits in a balance.
It's definitely a rolling road job. There's no way would I have the skills to set that up myself.
Keep an eye out on eBay for the MSD ignitions. They surface now and again at good money. I sold mine for something like £60, and bought it for similar. They're £300 new.
[Edited on 28/1/16 by FuryRebuild]
snapper - 28/1/16 at 04:13 PM
Idle for Pinto is usually 10-12 degrees then ramps to 34 to 36 at 3,600rpm flat after that
The vac advance is for part throttle
You should mark the pulley so you can see 8,10,12,14,16 degrees then 30,32,34,36,38
You can then set idle to something comfortable and use a strobe to view what is actually happening
Get a mate to gently increase rpm from idle noting the approximate spark advance
you should see about 10 degrees per 1000rpm to 3600rpm 36 degrees
Try this with and without vac advance
If vac is already disconected the vac advance plate may be swinging on its own thus pushing you spark advance all over the place
coozer - 28/1/16 at 04:18 PM
Put a trigger wheel and coil pack on it..
bumpy - 28/1/16 at 04:21 PM
The crank pulley is standard, with standard marks. I haven't checked it against a measured TDC and perhaps that's something to do, but I would be very surprised if its more than a degree or two out, given that its on a keyway.
mcerd1 - 28/1/16 at 04:30 PM
^^^ the reason I asked about the pulley is there are several types of OE ones...
The later ones have a 2 part design with a rubber isolator between them and although I've never heard of it on a pinto it is possible that the rubber slips and effective offsets the marks relative to the keyway (this is apparently quite common on some old yank v8's that use similar pulley designs)
If you are near this part of the world I've got various spare bits you'd be welcome to have / borrow to get to the bottom of this..
bumpy - 28/1/16 at 04:37 PM
That sounds like a plan
Under normal driving the vacuum is attached.
I am using the following timing light so I can measure any level of advance by electronically trimming it to 'TDC' using the adjustment wheel and reading off the degrees from the dial.
I guess if I turn the distributor to get 36 degrees of advance at 3600rpm that should be perfect for power delivery. After that I can measure it at tickover and decide if it starts or not and then tackle that end of the rev range.
bumpy - 28/1/16 at 04:40 PM
Thanks for that offer, but I'm nearly the length of England away from you. I have checked the pulley against one I have my spare engine and they're identical
mcerd1 - 28/1/16 at 04:41 PM
Which version of the dizzy do you have ?
bumpy - 28/1/16 at 04:51 PM
Both dizzys I tried were Bosch. I also tried a substitute ignition ECU without any benefits.
gremlin1234 - 28/1/16 at 05:03 PM
is this the same engine as
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=194506
mcerd1 - 28/1/16 at 05:04 PM
So they are all the electronic type then - I'd try the ignition module next if 2 dizzys gave the same results
I don't suppose you have a points based one to swap ?
rusty nuts - 28/1/16 at 08:00 PM
My guess even though you say you have checked them would be sticking Bob weights or weak springs causing the Bob weights to advance the timing even though the engine speed is low . You have the right type of timing light to check the timing advance.
BaileyPerformance - 28/1/16 at 08:36 PM
Have you chk'd the cam timing?
As already been said, pintos do like a quick advance curve, idle 16, total 32-36 all in by 4000rpm ish.
MSD6A won't retard timing during starting unless you buy an MSD starter saver to go with it.
Some pinto dizzy's are abit odd, very little timing in the dizzy, sometimes they rely on the vac advance to top up the advance. The vac connection to the engine is important, if a weber there is a port on the side of the carb that still has a vacuum signal with WOT.
I suggest you chk the total advance (with vac off) you should have about 34deg at 4000rpm
bumpy - 28/1/16 at 09:35 PM
Yes it is. The engine performance (assembled by someone else) was compromised in a number of ways when I purchased the car, and it has been like peeling back the layers of an onion, solve one problem and reveal another.
Problem 1 was that the car would hesitate and needed lots of revs to pull out at junctions - solved with new fuel pump
Problem 2 was that the throttle cable assembly was not operating fully to open the second of the progressive chokes - solved with a bit of re-engineering
Problem 3 was that the tick-over was very erratic - solved by replacing a GT camshaft of unknown origin with a standard camshaft.
Problem 4 is to optimise the ignition timing - work in progress
I am nothing if nor persistent
bumpy - 28/1/16 at 09:36 PM
You might have missed it but I have tried a second ignition module without improvement.
bumpy - 28/1/16 at 09:40 PM
Out of interest is it possible to buy bob-weight springs of different 'strengths'
If I decide to treat my car to a new distributor they seem quite reasonable at about £60. The two main manufacturers seem to be Powerspark and Accuspark. Is either of these preferred?
[Edited on 28/1/16 by bumpy]
gremlin1234 - 28/1/16 at 10:07 PM
certainly is
a very quick search found
http://www.distributordoctor.com/distributor_advance_springs.html
also, I did get a distributor from powerspark, - it just works, (but that was for a vw polo! )
snapper - 29/1/16 at 06:27 AM
I have fitted Megajolt to several Pintos
It gives you total spark control
From reading all your thread I can see that you changed the camshaft from a lumpy one to standard
My first thoughts are
Did you re time the new cam?
Did you change valve springs to match cam?
Did you change carb jets to match standard cam?
What spark plugs are you running? May be the ones for the GT cam are wrong for standard cam.
What is the compression ratio of the engine? If this was higher than standard for the GT cam you may now have detonation due to even higher combustion pressure due to much reduced standard cam overlap.
I'm getting the feeling the problems started after GT cam was changed for standard one.
FR32 is a good road cam easy idle that is very street drivable
RL31 is the max for road with a lumpy idle and sharp on cam power at 3500rpm
I think you engine was set up for something like an RL31 and by changing to a standard cam you have a huge miss match of settings, the ignition problem may only be part of the issue.
bumpy - 29/1/16 at 09:44 AM
Its an interesting thought, but my engine had a GT cam of unknown origin and all other parts were standard - carb jets, valve timing, springs etc which is probably why it ran so erratically!
My target has always been to restore the engine to standard specs, so I am not at the mercy of someone who thought they knew how to tune it. So everything is now at standard spec including the camshaft, springs and followers from Burton, spark plugs etc.
The builder assured me that the engine had had a re-bore, new 'standard' pistons and a very mild head 'skim' to ensure no distortion, so I would think the engine is at pretty much standard compression.
At no time since I have owned it has it ever suggested to me (during driving at any revs) that it is anything more than a standard lump.
mcerd1 - 29/1/16 at 11:05 AM
What kind of tools do you have available for diagnostics?
Do you have a dial gauge and a protractor (timing disc) ?
These would let you confirm all the basics and eliminate alot of possible causes
First off you should double check the real TDC location - its worth doing just so you know that you've got a good reference for all the other timing measurements.
Assuming that you'd rather not take the engine out of the car, you'll need to get a timing disc and mount it on the crank with some kind of pointer (I just bent one out of some heavy wire and bolted it to a spare mounting hole on the block)
Then you'll need a piston stop, these are easy to make using an old spark plug hollowed out with some threaded bar through the middle - the bar should be just long enough to stop the piston a few degrees before TDC.
So you turn the engine over slowly by hand until it just touches the stop and mark the position on the timing disc, then you turn it over backwards until it just touches from the other side and mark that position too.
The true TDC it exactly half way between these marks - so remove the stop, turn the engine to this true TDC mark and zero the timing disc.
So now you can see how close the timing marks on the pulley really are. (they are almost never perfect)
If you've got a dial gauge you can the go on to check the crank angles for your valve opening/closing/max lift.....
It might seem OTT but its easy to do and the tools are pretty cheap (dial gauge + mag stand can be less than £20)
And it will let you confirm the spec of your engine, regardless of what's been done to it in the past.
[Edited on 29/1/2016 by mcerd1]
bumpy - 29/1/16 at 11:12 AM
Thanks, looks like a worthwhile option.
bumpy - 29/1/16 at 11:16 AM
Looks like I have enough help and info to carry me into the Spring when I get the car out of storage.
The only place I am a bit short of info is preferences between buying a new Accuspark or Powerspark distributor?
Any bad experiences?
mcerd1 - 29/1/16 at 11:31 AM
Have you looked at the ones from H&H ignition
The guys are really helpful and know pinto dizzys really well
britishtrident - 29/1/16 at 12:32 PM
Centrifugal advance mechanism need lubrication, from slightly bitter experience I found washing in a parts washer washes the lubrication out and makes them stick. All that is required is tiny drop of engine oil on the spindle screw under rotor arm an a drop on each of the bob weights.
The sticking tends be more common on electronics versions because the points version gets rattled a bit by the vibration and drag of the contact breaker mechanism.
Chris_Xtreme - 29/1/16 at 04:25 PM
I think I have a ford pinto dizzy or 2 sitting about in the garage if they could be of any use to for a few beer tokens. I see the new ones are (only!) 50quid so I can see how buying new could be more of a certainty.
Also if you had a different cam and went back to a standard one, it could be that the weights were moved (what atspeed did to my pinto dizzy when I changed the cam) to adjust the advance curve, so now you are back at stock the curve is wrong.
u2u me if you are interested in the dizzys.
Chris
bumpy - 31/1/16 at 09:40 AM
Something that I don't know the answer to.
When I used to set the timing on cars with points using a fag paper, the engine was static and the bob weights would be fully closed. When I set the advance at idle (say 900rpm) are the bob weights still fully closed or have they already started to open?
[Edited on 1/2/16 by bumpy]
steve m - 31/1/16 at 10:02 AM
Has the engine always been like this? or has it just started to misbehave, if so what has happened between it was good and now
ie has the engine been pulled apart
has the cam timing been checked ? as the pinto will run with it a tooth out, albeit poorly, but enough to be able to drive
steve
bumpy - 31/1/16 at 10:59 AM
steve
So many other issues that its difficult to tell, but I never remember it accelerating particularly well, but its in a car where that's not the top priority.
rusty nuts - 31/1/16 at 11:19 AM
If the head has been skimmed by any amount it will alter the valve timing, retarding it . The Burton power website shows how to check and set valve timing correctly ignoring any timing marks which may not be accurate. Have you checked and adjusted the valve clearances to the correct settings? As already suggested it sounds like the ignition timing is not advancing/retarding as it should probably due to a partially siezed mechanism due to standing or not being lubricated . Strip the distributor taking off the top part from the main shaft ,small circlip IIRC , polish the shaft , lubricate and reassembly making sure the two parts can rotate against each other to fully advance and retard positions. Even putting some penetrating oil down the shaft may help, there may be a felt pad under the rotor arm which should be slightly dampened with oil every service. I
