ZZR1100 prop adaptor/ reverse sprocket
nick9one1 - 5/12/16 at 02:54 PM
I've just had a reverse sprocket cut by my local laser cutters. I got the plans (dwg) from another post on here.
Really happy with the quality and cost. £4.28 inc VAT! (10mm mild steel)
As it was so cheap, I'm thinking about having the rest of the sprocket adaptor cut by them.
a bit like this -
to end up with something like this
Off the shelf sprocket adaptors are about £85 inc P&P.
I can probably get this cut for less than £10.
As I'm building a sandrail, the engine is directly mounted to the diff. There is no UJ between the two, so alignment is going to be quite important.
also I dont know if the off the shelf parts are hardened?
[Edited on 5/12/16 by nick9one1]
minitici - 5/12/16 at 05:35 PM
Yes the sprocket adaptors are hardened (the ones from Talon certainly are).
Without hardening the splines will no doubt just rip out.
You can get away with a laser cut gear for your reverse as it sees a lot less stress on the teeth and is only used occasionally and does not have a gear constantly meshed.
