Sierra diff question.
gaz_gaz - 27/3/17 at 01:34 PM
Afternoon folks,
Can anyone help me out, I'd like to know,
If i have a 7" Sierra OPEN diff with 100mm lobro flange, And a 7" Sierra OPEN diff with push in shafts,
Can the flanges be removed from 1 and used in the other?
second question.
Am i correct in thinking that the Lobro flanges from an OPEN 7" Sierra diff can be used with a Quaife ATB after machining in a snap ring groove?
thanks in advance
Gary
rusty nuts - 27/3/17 at 05:19 PM
I believe that the push in shafts came in at least 2 different diameters which may cause problems if you have the wrong ones?
feckn7 - 27/3/17 at 06:51 PM
I've just been through this.
Ii have a 3.62 open diff with lobro and I bought a 3.38 open diff push-in type.
In my case the drive flanges from the 3.62 diff pushed straight into the 3.38. Only issue was when I put the circlips on the diff was like a locked diff. Seems the circles are too thick for the 3.38 and jammed the spider gears. Making the circlips thinner fixed that.
