Not messed with modern flywheel/clutch setups much but would the collective say the engine in this ebay auction has a Dual mass or a single mass
flywheel????
Based on the year it might be either.
Thanks in anticipation!!
2000 VOLVO V70 MK1 2.4 PETROL MANUAL (B5244S2) 140 BHP BARE ENGINE GOOD RUNNER
[Edited on 17/11/17 by liam.mccaffrey]
Doesnt look like a dual mass to me. They usally look much thicker and complex
That looks like a dual mass to me.
Edit well it does in the first pics but second from last it looks single mass. .
[Edited on 17/11/17 by big_wasa]
Pretty sure there is a line following the bolts on the working face, dual mass to me.
He's posted the engine number, and a quick search for 'B5244S2 flywheel' seems to suggest a DMF is standard fit.
Thanks guys i think DMF also
DMF and not a cheap one (if any are)
Deffo DMF looking at those pictures. I have one just the same sat on my bench.
I think they all are dual mass on Volvo's of that age mine also, I have many of the manuals and haven't seen any single mass ones
referenced. Seem to be well made though. Watch when you split the clutch they need a special tool to reset the internal adjuster. Not a normal clutch
on them. Get a manual if you don't already as these are complex machines.
[Edited on 18/11/17 by Mr Whippy]
They are not all DMFs, some models of 850 V70, S70 and C70 had solid flywheels.
See this listing
http://www.skandix.de/en/spare-parts/engine/engine-repair/
crankshaft/flywheel/1016656/ This is the part the Volvo fellas use to do the conversion from DMF to solid flywheel.
See this listing http://www.skandix.de/en/spare-parts/engine/engine-repair/ crankshaft/flywheel/1016656/ This is the part the Volvo fellas use to do the conversion from DMF to solid flywheel.
