I have bought an unused secondhand Duratec lightweight flywheel
The original Duratec clutch cover has a 6 x 240mm PCD
The Pinto clutch cover has a 6 x 245mm PCD
The Duratec flywheel has a 6 x 250 PCD
Any idea what fits this PCD?
I can’t find clutch cover PCD anywhere
I have an answer here (if of any use now), the sbd duratec flywheel (and the caterham oe) uses a cp5905-1 cover, which is originally for a mg zr and
has 6x250mm pcd mounting bolts.
It also uses a thinner drive plate than a standard pinto plate (7.2mm instead of 8.4mm), an ap pinto plate and a helix mgb/triumph plate are both
suitable.
A standard pinto plate would be unlikely to disengage with the clutch operated unless the cover was shimmed out, or the flywheel was stepped.
Dave
