Pinto EFI to carbs
GTO - 11/5/03 at 09:16 AM
i have a 2.0L pinto which is running on EFI but i realy want carbs
is this a hard job chageing the ign etc.
theconrodkid - 11/5/03 at 02:08 PM
the dizzy has no advance,it is all done by the ecu,you can change the dizzy to carb type,the rest is straight forward though there was mention of a prob where the injector cut outs were in the head. ill have the inlet if u want to get rid of it
GTO - 11/5/03 at 09:41 PM
if thats the case i got a full injection system here for sale if anone wants it or will work somthing out with a swap for carbs/ignition
chrisg - 11/5/03 at 10:01 PM
You really need a carb head as the inlet ports are round as opposed to pear shaped on the injection head. although you can get round it with an adaptor plate.
I THINK conrod wants an injection system.
cheers
Chris
theconrodkid - 12/5/03 at 07:04 PM
who,s side u on chris?
