ned
posted on 9/2/04 at 11:03 AM |
de-dion pics please!
Can anyone post up pics of the dedion stup as darresn web pics are a bit dark/vague. interested mainly in the hub end of the axle pics.. traling arms
mount positions etc.
Darren,
Is there any neg camber or toe in on the beam?
Is it possible to order the beam without the trailing arm mounts incase i want to position them myself?
cheers,
ned.
beware, I've got yellow skin
dozracing
posted on 9/2/04 at 11:18 AM |
Hi Ned,
You can put camber and toe in very easily to the beam. Yes we can do just the beam for you and there will be more pics coming soon of the beam off of
the car.
Kind regards,
Darren
ned
posted on 9/2/04 at 11:42 AM |
Darren,
Thanks for the quick reply! Any idea how long the extra pics will be, I'm an impatient bugger.
My reason for possibly changing the trailing arm points is to accomodate some changes i made to my chassis when i was originally going to go IRS.
I hope this pic shows, where I removed the book trailing arm points an put some 2x1 in on the ends of the cockpit rear bulkhead.
Any ideas round this would be appreciated. What should be the minimum length of trailing arms. one book i've read suggests 8 inches..
cheers,
Ned.
ed_crouch
posted on 9/2/04 at 11:53 AM |
chaps,
I have a 3D CAD model of a DeDion Beam based on some sketches on Craig Chaimberlain's website. DeDion is something I want to get into when i get
the car on the road, so there will be more development on the design.
There is a picture of the beam design on my website:
http://www.wings-and-wheels.net
Its under locost files, planning and modelling
Ed.
P.S. Ned, have you still got those Sierra rear hubs (if you ever did have the hubs *memory fails*)??
I-iii-iii-iii-ts ME!
Hurrah.
ned
posted on 9/2/04 at 11:55 AM |
Ed,
the hubs are required for my dedion axle! the rest is/was scrap as it was the heavy trailing arms off the sierra.
ned.
ed_crouch
posted on 9/2/04 at 11:56 AM |
no worries, chap!
Ed.
Hurrah.
ned
posted on 9/2/04 at 12:05 PM |
would there be any detrimental affects to moving the dedion axle trailing arm mounts further back, slightly behind the axle?
Ned.
nige
posted on 9/2/04 at 12:09 PM |
have you looked at the locost cd
that david dunn does ?
this gives good pics of dedion set up.
we are going dedion ,the trailing arm
position on yours looks to be further in
if this is the case then the hub carrier tube
would need to be longer , if you use standard width shafts .
not expert but giving it a bloody good go
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
timf
posted on 9/2/04 at 12:20 PM |
ned the changes to the book chassis are on darrens site http://www.cougarracing.fsnet.co.uk/dedion.pdf
btw i though you were going into hibernation for a while
ned
posted on 9/2/04 at 12:46 PM |
Tim,
Thanks, I've seen that diagram already. only going into hibernation with regards to working on the car. can still keep buying bits for it! just
won't work on it for a bit. couple of months hopefully to sort the house move...
Ned.
pbura
posted on 9/2/04 at 01:56 PM |
Ned,
Why not just pop in some new M tubes for mounting your trailing arms?
You could still use your idea for placing the axle pivots a bit farther back, as the standard trailing arms are not very long to begin with.
It's not like you're going to be scarfing up your powder coat or anything
Pete
Pete
ned
posted on 9/2/04 at 02:14 PM |
Pete,
I don't have my 'book' to hand, are the m tubes the book chassi trailing arm mounting points?
If they are i'd need to cut out the 2x1 i've put across the cockpit bulkhead where the trailing arms would go which i don't really
want to do. this is the only reason i'm considering moving the axle traliing arm mounts further back.
cheers,
Ned.
pbura
posted on 9/2/04 at 04:01 PM |
Oh, yeah, I see now.
Yes, the 'M' tube is for mounting the trailings arms. I had to look it up for my earlier response
You have shortened halfshafts so you don't have a lot of room between chassis and wheel, right? In that case I think cutting out the
1"X2" would be the way to go If you have room, you could hang your brackets (or bolts for rod ends) outboard a bit, but this
wouldn't be very strong, I suppose.
BTW, one neat method Mike Laws of Oz and others have used is to weld a box made of 1"X2" U channel to the 'M' tubes instead of
brackets, making a very secure mounting.
Good luck!
Pete
Pete
ned
posted on 9/2/04 at 04:04 PM |
Pete,
I'm gonna use standard sierra track, which is slightly wider than book locost, though i guess it depends on where the pickup up points are put
on the axle/chassis...
Ned.
ned
posted on 9/2/04 at 04:47 PM |
I've just priced up what I'd need for he dedion rear end and it has come to [shock] £282.50 + delivery [/shock]
this isn't much cheaper than the mk rear end which i had priced up a couple of months ago.
what makes me even more annoyed is that i had a set of trailing arms and a panhard rod that i sold for only £25 and the trailing arms alone from gts
are £44.
I'm annoyed now
Ned.
pbura
posted on 9/2/04 at 08:27 PM |
Holy crap! That's a far cry from £150, I'd say.
Given any thought to making your own? Here's a couple of inspirational links:
http://au.geocities.com/phil1rowe4/rear.html
http://www.craig.chamberlain.name/locost/Diary-200306.htm
Pete
dozracing
posted on 9/2/04 at 09:26 PM |
Ned,
How do you work out that its £200+?
In the £150 you get the Panhard rod, DeDion axle, trailing arms. The only thing you need is the diff mounts unless you fancy making your own, they are
only £12. So its a long long way off your sums.
Please don't publish prices like this when they are inaccurate as its gives people the wrong impression.
Whats more important is the comparison of prices against the other suppliers and i think you'll find that you can't get parts from MK or
Luego cheaper. You probably can from Lolocost, but, then why would you want to settle for inferior quality for a pound or two saving.
Kind regards,
Darren
M@Triton
posted on 9/2/04 at 10:15 PM |
The de dion axle set up gets you a lighter car....IRS is heavier much heavier as there tends to be more gubbins to hang wishbones on......most look
complete tosh too and don't do what it says on the tin....ie adjust!
If i could post pics i would but it doesn't want to play ball....sorry
Regards
Mark@Triton
ed_crouch
posted on 10/2/04 at 08:32 AM |
Well, there we go!
Doz, I am building a plus4 chassis, and hence the trailing arm mounts (when i go for Dedion: am going to get it on the road with a LRA and then swap
when the Rover V8 goes in!) will want to be 100mm further apart than for a book chassis. Can you weld them on further apart, or would i need to modify
the axle myself??
Ed.
Hurrah.
ned
posted on 10/2/04 at 10:22 AM |
Darren,
My sincerest apologies, I hadn't realised that the dedion axle included the trailing arms and panhard rod, I'd added this all on top of
the axle, along with the caliper plates, rod ends etc etc to reach that figure. In this light, I'm very happy to agree that your kit is much
more attractively priced than MK or luego's. MK quoted me around £320 for their wishbones, uprights, bolts, bushes and brackets etc for their
rear end!
Am I right in thinking that I'd still need to add on the cost of bolts/bushes/disc brake caliper mount plate, rod ends to the basic axle kit?
Thanks,
Ned.
dozracing
posted on 10/2/04 at 11:23 AM |
Hi Ned,
You do need to add on the bolts and bushes etc, but i guess you already have most of them for the front, so the few that you need for the rear setup
will be much cheaper.
Kind regards,
Darren
ned
posted on 10/2/04 at 11:35 AM |
Darren,
Can you sell me half a set of bushes/tube? enough to do the rear. the ones on the front are locoshite and i damaged some of them when trial fitting,
so don't have enough to do the rear. the bolts i have should be ok assuming they're the correct size!
are the rod ends included with the panhard rod or will i need to order them seperatley along with the caliper mounting plates?
Thanks,
Ned.
M@Triton
posted on 10/2/04 at 06:32 PM |
Ed, the trailing arm mounts are integral to the joint between ..... axle tube,end casing and hub mounting flange all jigged.
The only way really to make it 100mm wider is to alter the centre of the tube and leave each end well alone....make up a temp jig to hold it where you
want and bingo.
![](/galpreviews/a84411-De-Dion axle end view.jpg) ![Rescued attachment De-Dion axle end view.jpg](/gallery/a84411-De-Dion axle end view.jpg) Rescued attachment De-Dion axle end view.jpg
Stu16v
posted on 10/2/04 at 11:04 PM |
M@Triton, *I think* he is referring to the trailing arm brackets needing to be 100mm wider than 'book' as opposed to the whole axle
itself. Unless that is what you mean too of course, in which case please ignore me....
Is the dedion designed for a 'book' width chassis with standard Sierra running gear/width?
Looks to be nice fabrication in piccy by the way gents....
[Edited on 10/2/04 by Stu16v]
M@Triton
posted on 10/2/04 at 11:49 PM |
Yes the axle is designed to suit the "book" chassis and yes again it is full width Sierra.
Sounds like tricky shaped trailing arms then or mod the chassis
And thanks for comments by the way.
