Author: Subject: Wtd: SVA friendly Exhaust Can, Buy/Borrow?
nitram38
posted on 20/4/09 at 09:17 PM Reply With Quote
Just failed with a quill T3 5" carbon Can at 103dbA.
I need one that fits on a stainless 52mm OD pipe and will get me through the sva noise test of less than 101 dbA.
Cheers Martin
907
posted on 21/4/09 at 07:14 AM Reply With Quote
The problem is I'm in north Essex, but I have an original Thunderace can that has been though a couple of SVA's.
It's had the bracket removed and the inlet modded to slide on 2" pipe.
On Jon Beadle's cross flow it passed at Norwich (87dba)
You would be welcome to borrow it, or maybe look for the same sort of thing on eBay.
nitram38
posted on 21/4/09 at 07:18 AM Reply With Quote
I think that it will be different on an R1 as mine is checked at 8800 rpm.
I really need something that has been proved on this engine. Thanks for your offer. Cheers Martin
907
posted on 21/4/09 at 07:27 AM Reply With Quote
A T/ace and an R1 is the same engine, give or take a couple of tweaks.
It was the 5 speed g/box that was the downfall of the T/ace.
Didn't cut the mustard as a sports bike but it was bl**dy quick enough for me.
Paul G
nitram38
posted on 21/4/09 at 07:38 AM Reply With Quote
The only problem is that I have a bike can and it failed sva.
They are built to lower standards than a car and only have to pass a driveby test at max 84dbA @ about 30mph and at about 20ft away.
The car test involves putting the sound meter 500mm away and on idle a standard bike can is already at 82dbA.
At 8800 rpm the can might as not be there!
907
posted on 21/4/09 at 07:53 AM Reply With Quote
OK Martin, no prob.
Paul G
Dangle_kt
posted on 21/4/09 at 08:48 AM Reply With Quote
you will find a good oem silencer far quieter than your quill, its designed to be quiet at low rpm, and 8800rpm is not low rpm.
Also any aftermarket end can is not designed to get the bike through the emissions and sound tests that the manufactuers have, so they are always louder, at least at some point of the rev range.
The OEM silencers are considered resitrictive and are often removed becuase of this.
I'd recommend at least trying an OEM silencer, like the kind offer above before pooh poohing it. I might have misread his post, but all it will cost you is postage I think, and thats not much to loose on a car worth as much as yours.
nitram38
posted on 21/4/09 at 09:33 AM Reply With Quote
I'm not pooh poohing it, I just don't want to keep trying things as I want to try and get the car on the road for at least one of the bigger summer shows and time is getting shorter. There is only one tester at Mitcham so getting a re-test is going to be slow and the reception I got from wimbledon vro wasn't exactly confidence building.
If someone says that the thunderace can, will pass, then that is the route I will go.
I just need someone to say that they went this route first.
Cheers Martin
posted on 21/4/09 at 09:51 AM Reply With Quote
The new Fazer has an exhaust valve similar to an exup but it is not to enhance performance but to reduce the drive by noise to meet the more stringent levels now imposed. Can you fit an after market baffle to a can for the test like the ones race cans use for MOT time ?
Dangle_kt
posted on 21/4/09 at 10:02 AM Reply With Quote
sorry, ref my earlier comment - I didn't mean it to sound quite as harsh as it came out.
I knew I had read some where about the quill cans, I remember it from when I used to always buy bike mags, and they had just launched the T3.
I had a rummage through there website as I've obviously binned the mag I read it in, and this is what I found.
"The T3 has a unique exhaust note, reasonably quiet up to 3,000 revs, but an impressive straight through race sound after 4,000 revs."
So I really do think a standard OEM can could make the 2dB difference at 8800rpm.
Did I read you have a noise meter? You could fit it and test it (I know its not calibrated, but it will be close) within an hour or two.
anyway, if no one comes back with any better ideas, it might be worth a punt.
Lots of people have passed with that engine, using the standard can - but obviously not your manifold and downpipe set up as I bet that is unique.
That will make a difference, so I doubt anyone could definativly say it will or won't work unfortunatly.
nitram38
posted on 21/4/09 at 11:52 AM Reply With Quote
I've just spoken to Martin Keenan (MK engineering) who will sell me the bits to make up my own can. He is currently too busy to make one, getting a car ready for sva and the show.
My idea is increase the length and to put a right angle on the exhaust exit because this will mean the sound meter being turned away from the rear of the car and less likely to pick up any reverb from my rear firewall.
My induction noise shouldn't be a problem as I have a standard airbox that is ducted forwards of the engine.
I'll post the results once done!
ReMan
posted on 21/4/09 at 10:55 PM Reply With Quote
I would suggest a suzuki 1200bandit can
Very cheap on the bay, flange to slip on adapter available very(too) quiet for me so I cut one I half
[Edited on 22/4/09 by ReMan]
nitram38
posted on 21/4/09 at 11:02 PM Reply With Quote
Any dimensions for the bandit can?
What revs did they test yours at?
Mine was 8800 which seems a bit higher than most.
ReMan
posted on 22/4/09 at 12:12 PM Reply With Quote
Sorry Martin, I SVA'd with a std R1 can, this at about 7000
You must have set a very high RPm on your SVA form.
Not at home at the moment the Bandit can is about 1" bigger diameter at a guess and really was to quiet for me post SVA.
But I can't guarantee what the output will be for you , sorry.
However, I'd lend you my flange and if you get a can cheap I'll take it of you if it's no good as I want a quiet track day can
nitram38
posted on 22/4/09 at 04:47 PM Reply With Quote
I sourced a 6" powerflow silencer today and fitted it. (same length as the quill)
It is worse now at 106dbA !
Luckily I had the foresight to get one with a right angle tail pipe so tommorow I am going to fit the Quill box onto that so there are two boxes!
Watch this space.
[Edited on 22/4/2009 by nitram38]
nitram38
posted on 23/4/09 at 01:17 PM Reply With Quote
Oh crap.....it's worse with both boxes!
I'm pulling my hair out.
Where can I fing the official power figures for an 05 R1 engine?
The only way this is going to pass is if I get the test rpm lowered.
ReMan
posted on 24/4/09 at 06:48 PM Reply With Quote
Bizzarre
Perhaps you could print off a spec sheet I'm sure I saw on the internet that peak power is 9500rpm
nitram38
posted on 24/4/09 at 07:35 PM Reply With Quote
I already have two at 10500 which is more realistic.
The sva tester said if I had evidence he would alter the test requirement.
At 8000 rpm I measured 100dbA, so I hope it will pass!
