<<  1    2  >>
New Topic New Reply
Author: Subject: If square tube is stronger, why are most fancy chassis made from round?
mr henderson
posted on 15/5/09 at 03:54 PM Reply With Quote
From time to time I have a look around at what is out there, picking up tips and ideas, and from time to time I look at what sorts and types of chassis people are making.
So, just as the title says, why is it that so many chassis are built of round tube?
John
[Edited on 15/5/09 by mr henderson]
sucksqueezebangblow
posted on 15/5/09 at 03:57 PM Reply With Quote
'Caus round tube is stronger for a given weight. Thus round tube chassis are stronger and lighter. The downside is that you need a notching machine for round tube joints while square tube joints are just mitred.
mr henderson
posted on 15/5/09 at 03:59 PM Reply With Quote
If it is stronger for a given weight then surely that's either stonger or lighter?
smart51
posted on 15/5/09 at 04:01 PM Reply With Quote
Round tube can be run through a bending machine too, so less cutting and welding.
I used round tube because its lighter than square of the same size. It is also more torsionally rigid I believe but not quite as strong in tension.
Liam
posted on 15/5/09 at 04:10 PM Reply With Quote
Why? Take a chassis design made from square tube. You decide to make the same design out of round tube. Depending on your choice of round tube, you might make it just lighter with the same strength, you might make it just stronger with the same weight, or any combination between - i.e. both a little bit stronger and a little bit lighter.
Liam
[Edited on 15/5/09 by Liam]
nasty-bob
posted on 15/5/09 at 04:22 PM Reply With Quote
Round tube is stronger in torsion and square tube is stronger in bending.
In theory, the centreline of the chassis is in torsion, so here it is better to use round tube, the further you move from the centreline the more the tubes become subject to bending. So there is a point at which it is best to switch.
Of course a proper spaceframe only has tubes in tension or compression, so none of that is relevant.
So what it really comes done down to: round looks better but square is easier to build with.
Rob
dinosaurjuice
posted on 15/5/09 at 04:24 PM Reply With Quote
'stronger'
tensile strength for same grade steel is CSA - therefore stronger = heavier.
strength in bending is 2nd moments of area - square profile uses CSA more efficiently
compression in slender members is also 2nd moments of area - square wins (if the diamater of round was same as square)
torsion is based around r^3, cirular section provides more efficient distribution of stress.
CSA = cross sectional area
IMO it depends entirely on how well used they are - a chassis using round should be desinged differently to a chassis using square.
Will
[Edited on 15/5/09 by dinosaurjuice]
posted on 15/5/09 at 04:39 PM Reply With Quote
Round tube is lighter, for any given strength so you can put more tubes in the chassis for less or the same weight.
kb58
posted on 15/5/09 at 04:52 PM Reply With Quote
The issue really answers itself. Where panels attach, square is used, while round can be used elsewhere. One may be theoretically better but it doesn't matter if it makes fabrication impossible.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
austin man
posted on 15/5/09 at 04:59 PM Reply With Quote
Notching machine to cut joints what about using a hole saw(metal cutting type as use by sparkies) in the pillar drill way cheaper
mr henderson
posted on 15/5/09 at 05:02 PM Reply With Quote
Not so good if you need a 45degree angle though.
clairetoo
posted on 15/5/09 at 05:24 PM Reply With Quote
Easy enough if you have one of these
Another point is - where do you get square CDS or chrome moly if you want a higher spec than ordinary mild steel ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
Volvorsport
posted on 15/5/09 at 05:27 PM Reply With Quote
if you want T45 , you need to ring malcolm wilson up !
www.dbsmotorsport.co.uk
getting dirty under a bus
Steve Hignett
posted on 15/5/09 at 05:29 PM Reply With Quote
I have one of those!
Bought it from ebay US though and had it shipped over as a gift...
There is one on ebay ATM though!
EBAY TUBE NOTCHER
Steve Hignett
posted on 15/5/09 at 05:31 PM Reply With Quote
I think this is the one that I bought - he happily labelled it as a birthday gift for me...
TUBE NOTCHER FROM THE STATES
designer
posted on 15/5/09 at 05:55 PM Reply With Quote
All the above.
Plus, round tube chassis look better!!
mr henderson
posted on 15/5/09 at 05:56 PM Reply With Quote
Indeed, that is a tube notcher. I understood Austinman to mean that you could do it without one.
wozsher
posted on 15/5/09 at 07:00 PM Reply With Quote
I build round tube chassis for a living,the reason square is used is simply that it is less labour intensive,it is much easier and cheaper to manufacture.
fesycresy
posted on 15/5/09 at 07:21 PM Reply With Quote
I could answer this question with all my mechanical design knowledge, all the time sitting through those boring dynamics lectures absorbing all that information, but it can be summed up simply....
....because it looks prettier
mr henderson
posted on 15/5/09 at 07:36 PM Reply With Quote
I've suspected that for some time, glad to have it confirmed
wozsher
posted on 15/5/09 at 07:53 PM Reply With Quote
Your missing the point
mr henderson
posted on 15/5/09 at 08:05 PM Reply With Quote
Who is missing the point, and what is the point?
clairetoo
posted on 16/5/09 at 05:21 AM Reply With Quote
Theres a point ?
Claire xx
procomp
posted on 16/5/09 at 09:14 AM Reply With Quote
Hi
Remember of course that the square tube dose allow the chassis to panelled correctly and act as a stressed member. IF done correctly. And that dose add significant strength.
Cheers Matt
Mark Allanson
posted on 16/5/09 at 09:29 AM Reply With Quote
I have heard that the paneling adds strength - I would like to see some evidence that unstressed, flat 1.2mm ally adds anything to the dynamics of the chassis. If it was in a 3 dimensional shape, I could see their point.
<<  1    2  >>
New Topic New Reply
