flak monkey
posted on 3/9/09 at 06:54 PM |
Some duratec supercharger calcs
I thought these may be useful for someone. I have just finished doing the system calcs for my supercharger. Of course these are theoretical....
2 litre engine (122cid)
Stock power 180bhp @ 6800rpm
Volumetric efficiency = 80% (generally accepted for modern 4 valve engines)
The volumetric efficiency of a centrifugal supercharger is 100%
VE Ratio = Supercharger VE/Engine VE
= 100%/80%
= 1.2
Pressure ratio (PR) estimate = desired BHP/stock BHP
= 340bhp/180
= 1.88
This tells you how much boost you need in theory to get your desired BHP, though its not always that simple!
So thats 13 psi of boost
Next calc the temp gain of the inlet air at that given pressure ratio.
Temp gain = (PR^0.28 -1)x Absolute temp)/Supercharger efficiency
= (1.88^0.28 - 1 x 77+460)/0.8
= 130 deg F
Density ratio (non intercooled) = Original temp/new temp
= (77+460)/(77+460+130)
= 0.8 (this is a 20% reduction in air density at this temp.
Obviously this is where intercooling comes into its own.
Assume an intercooler efficiency of 82% (pretty easily achievable if its got good airflow like mine will have)
Outlet temp of intercooler = 130 x .82 = 23.4deg F above ambient
So:
Density ratio (intercooled) = (77+460)/(77+460+23.4)
= 0.96
So only a 4% decrease in air density with an intercooler
Now you need to find out what your true pressure ratio needs to be (this could be higher or lower than your theoretical depending on your engine VE
and whether or not you have an intercooler)
I am using an intercooler so:
Pressure ratio = desired bhp / (stock bhp*density ratio*ve ratio*drive efficiency (90% is a good estimate))
= 340/180*0.96*1.2*0.9
= 1.82
So I need around 12psi of boost to get 340bhp
For non intercooled apps you use the same calc as above, but you need to do another iteration of the calcs with your new density ratio to get an
accurate result.
Next thing to do is calculate the peak airflow requirment, first calc the naturally aspirated airflow requirement:
Required airflow (CFM) = (CID*rpm*0.5*engine VE)/1728
= 122*6800*0.5*0.8/1728
= 192CFM
Boosted CFM = CFM*PR
= 192*1.82
= 350CFM
Convert to KG/s divide by 1731.8
So air flow = 0.2kg/s
This will let you pick the right rotrex.
Basically a C30-94 sits at about 80% efficiency at a 1.8 PR at this air flow. This also equates to about 75,000rpm impeller speed.
The stock crank pulley is 132mm on the duratec.
So:
Pulley ratio = impellor speed / charger internal gear ratio x redline rpm
= 75000 / 9.49*7200
= 1.097
So the charger needs a 132/1.079 pulley. Or 120mm
Now the biggest pulley rotrex make is 110mm, so there are 2 options. Hope that your intercooler pressure drop is high (2 psi or more) and use the
110mm pulley (every 5mm smaller equates to about a 1psi increase in boost which is handy) or get a smaller crank pulley from Raceco which is 100mm
diameter and use a 90mm pulley.
This is just my ramblings of tonights calcs. So if it doesnt make sense, ask
[Edited on 3/9/09 by flak monkey]
Sera
http://www.motosera.com
flak monkey
posted on 3/9/09 at 06:58 PM |
Also on the subject of intercoolers, I have had a quote from GRS and Pace to supply one which sits infront of the polo rad. It has a massive frontal
area meaning the efficiency temp wise will be high. Sadly the pressure loss will be around 2psi I think because of the small entry and exit areas.
The quote is around £300 from both companies.
If it will fit in your application I might be able to get more than 1 made at a lower price, but I havent asked yet.
Sera
posted on 3/9/09 at 07:36 PM |
The maths make sense to me. Only trouble is if you read Forced Induction tuning (Graham A. Bell) he states before virtually every equation that
it's only to get you into roughly the right ballpark.... e.g. the equations don't take into account the effect of airflow, valve timing
etc etc.
EG an engine with a "tasty" cam with masses of overlap will produce lots of power when NA due to better scavenging of exhaust gases. Strap
on forced induction and you won't get much more BHP due to all your lovely boost peeing out of the exhaust valve being kept open for such a long
amount....
Equally a poorly ported head with small valves and a restrictive air inlet will produce low power NA but a lot more FI when the flow changes.
Only issue I have with intercoolers is that most OEMs are built very long and wide (ie a few long tubes). Good efficient cooling but also very
restrictive....
matt.c
posted on 3/9/09 at 09:09 PM |
Got to ask how the fu*K do you know all that stuff!!!
My brain just fliped out looking at that stuff!
omega0684
posted on 3/9/09 at 09:46 PM |
disired bhp = 340
yee hee!
James
posted on 4/9/09 at 02:28 AM |
Favourited!
What higher compliment can be made Flak!
James
- Muhammad Ali
flak monkey
posted on 4/9/09 at 05:48 AM |
It will certainly be interesting to see how close the reality follows the theory.
The duratec std cams are very low overlap (helps with emmissions), high lift and moderate duration, so should in theory be well suited to supercharged
applications. Again....in theory!
I am going to lower the CR 1 point (to 9:1) and run 1 bar of boost in total, making the assumption I will loose around 2 psi through the intercooler.
Lowering the CR by a point is only going to make a very small difference lower down the rev range, but should make it a lot easier to tune higher
up.
Sera
jeffw
posted on 4/9/09 at 05:53 AM |
When I was running high power turbo Audis we used g/s / 0.8 to get the power output as an approximation. My RS4 ran 440 g/s through the MAF so 550
BHP which was validated on a Rolling Road (actually 542BHP). I assume this relates to your 80% efficient for modern cars.
If you run the same calculation on 200g/s you only get 250BHP not 340BHP. Since you can't produce any more power than the air that goes into
the engine I think your calculations have gone wrong somewhere. You will need 272g/s to make 340BHP using that calculation or I could be talking
complete nonesense
[Edited on 4/9/09 by jeffw]
goaty
posted on 4/9/09 at 06:37 AM |
this is very handy and interesting stuff. Not to sure how mine will turn out yet, want it to be a safely built engine so it is not stressed.
I wuold be very interested in the intercooler if you were having more than one made.
I currently run an escort rad and was planning to have the intercooler connection going round the side but think i shall measure up for a polo rad and
the set up you have shown.
cheers again
[Edited on 4/9/09 by goaty]
hughpinder
posted on 4/9/09 at 07:16 AM |
Just a note:
You calculated the VE ratio as 100/80 = 1.2, but 100/80 = 1.25 when I went to school!
Regards
Hugh
graememk
posted on 4/9/09 at 07:30 AM |
Google ?????
i know hes really Carol Vorderman
[Edited on 4/9/09 by graememk]
flak monkey
posted on 4/9/09 at 08:16 AM |
Just worked through the calculations in one of my supercharging books.
Sera
cd.thomson
posted on 4/9/09 at 08:47 AM |
Hey flak,
180 --> 340bhp
does the duratec require any uprated internals to run at 1 bar of boost?
interested in doing something similar with my XE after its on the road (preferably supercharged) so I'm interested in your setup. Which
resources are you using for the task? I understand its a bit of a headscratcher to get something like this working?
Are you pressurising the standard induction with a single throttle body or running forced ITBs?
[Edited on 4/9/09 by cd.thomson]
Craig
flak monkey
posted on 4/9/09 at 08:59 AM |
quote: Originally posted by cd.thomson
Hey flak,
180 --> 340bhp
I will be running forged rods and pistons, though there are some people who think running 11psi on stock 10:1CR internals is ok, and the engines seem
to last ok and see around 320bhp.
I will be lowering the CR by a point (9:1) to give me more scope in the future, but to be honest anything over 30bhp is going to be more than enough
and I reckon I will struggle to put it down on the road as it is.
The best resource I have found is a book called SUPERCHARGED! by Corky Bell. Its a mine of information, and very clearly written, covers all sorts of
chargers, intercoolers etc too.
Technically its not that complex, its getting t all running smootly after implementation that could be more difficult.
I am running a blow through set up, so throttle bodies mounted direct to the head, supercharger will be upstream of them. I will be using an
atmospheric BOV to prevent compressor surge when the throttle is closed. Single throttle body would work just as well though and actually be simpler
in the long run I would guess.
Sera
cd.thomson
posted on 4/9/09 at 09:05 AM |
awesome, thanks for that, ill keep my eye on it as it progresses .
Craig
omega0684
posted on 4/9/09 at 10:34 AM |
i hope that for all that money you mean 300 bhp
bimbleuk
posted on 4/9/09 at 10:56 AM |
I recognised the the format of the calculations a I used the same book for my research. My setup is very similar with ITBs and a BOV except I'm
using a 1.6 4AGE. I have 270BHP with 1 bar boost initially on 10.5:1 (cast pistons) but currently 9:1 (forged) but ideally you want closer to 10:1 as
the Rotrex works better with higher CRs.
If you haven't bought the kit already speak to Andrew at OMEX as they have done a lot of dyno work with Duratecs using the Rotrex. They could
save you some dyno time by using their experience but they are a business remember.
Oh and your intercooler looks to be approx 30% wider than my MR2 one I'm using in front of the Polo rad.
[Edited on 4-9-09 by bimbleuk]
flak monkey
posted on 4/9/09 at 11:29 AM |
Brilliant info, thansk very much.
So what was your reason for dropping the CR down to 9:1 if the superchargers work better with a higher CR?
I have the option of going for 9:1, 10:1 or 10.5:1
I will also get in touch with OMEX and see if they are willing to give any info away.
Sera
goaty
posted on 4/9/09 at 12:02 PM |
flak,
what management are you planning on using??
i ask as you said you will be running TB's blown through, but i have heard that getting the mapping set up on this can be a task and usually
involves two maps unless you use a MAF....
I am planning the simpler 1 TB with a map sensor to keep it in check.
cheers
flak monkey
posted on 4/9/09 at 12:39 PM |
quote: Originally posted by goaty
flak,
cheers
Dont see why, shouldnt make any difference as the ignition and fuel will be controlled using speed-density (MAP) anyway. So doesnt matter where the
throttle plates are.
Sera
goaty
posted on 4/9/09 at 12:48 PM |
does the map sensor not have to be on the engine side fo the butterflys??
how would it work across all 4??
flak monkey
posted on 4/9/09 at 01:02 PM |
Yep, its connected in exactly the same way as in a NA application using the vacuum lines on the engine side of the butterflies.
Pulses from each cylinder are apparently less of an issue when using forced induction.
Sera
bimbleuk
posted on 4/9/09 at 02:29 PM |
My engine is primarily mapped just like an NA setup with throttle angle, crank angle , water temp and inlet temp in the plenum. Then there is a map
sensor conneted across all the TBs to change the map as the inlet pressure changes. I'm using a factory set of ITBs which have a vacuum rail and
damping pot as part of the casting.
As for pistons I had a choice between a set of ACL 20V 10.5:1 forged pistons for £400-500 or a set of 16V 8.9:1 Toyota forged factory pistons for £150
(+£30 for fly cuts). Not a very difficult choice that one. Though similar power the engine felt much better on the 10.5:1 cast pistons until the ring
lands broke from the stress.
alistairolsen
posted on 4/9/09 at 09:49 PM |
the issue with tbs isnt the normal fuelling, its the transient fuelling because when you open the trottle you have an intake plenum full of boosted
air rather than having to make some.
My Build Thread
sebastiaan
posted on 6/9/09 at 11:35 AM |
David,
I took a quick glance at your calcs and you've seemed to have left out the power needed to actually drive the supercharger. At 340BHP@1 bar
boost, this is going to be significant.
Or; in the real world: just whack the nearest size pulley on and see what happens
Sebastiaan
