steve m
posted on 15/9/13 at 08:34 PM |
Tyre choice against speedo error
My speedo overheads quite a bit, ie at indicated 40 mph, I'm actually doing 31, and at 50 it's 40 ( on sat nav)
Now as my speedo has spent more time being repaired with a reputable place than on the dash board, I've given up with them
It's an analogue unit driven by the gearbox so no chance of calibrating it
If if I was to raise the rear tyre aspect ratio from 55 to 70 would this bring my speedo to a better closer level
Plus would this affect anything else with handling ??
daniel mason
posted on 15/9/13 at 08:38 PM |
that would depend on your tyre width. as the aspect is a percentage of width! if your on narrow tyres then a 205/60/13 may be the way forward. ive
always found thats the best size on the back of a 7 with 13" wheels. id also go for yoko a048's if budget allows
snapper
posted on 15/9/13 at 09:06 PM |
I think you approaching this from the wrong angle
There are different gears you can put in the gearbox to adjust
Or look at electronic
I eat to survive
I drink to forget
gremlin1234
posted on 15/9/13 at 09:12 PM |
lo-cost answer:
just put new marks on the speedo
steve m
posted on 15/9/13 at 09:13 PM |
The gears in the gearbox have been changed, and the other set are a lot worse!!
There are only two sets of gears for a type 2 gearbox
Going electronic is not really a viable option, as to have one made to match the rest of the dash, was quoted at £250 plus
And that does not include the sensors etc
steve m
posted on 15/9/13 at 09:18 PM |
I don't need a new mark, but good try!
As I just need to deduct 10 mph? And I won't be far wrong
It's more annoying than critical, and as the tyres really need to be changed as 14 years old, and were not new when I got them
And I was thinking. About a better spec tyre anyway
adithorp
posted on 15/9/13 at 10:02 PM |
Just put your current and proposed tyre sizes into one of the online tyre size comparison calculators. Quick google came up with
THIS but there's plenty more.
http://jpsc.org.uk/forum/
dhutch
posted on 16/9/13 at 07:10 AM |
Ditto, while I know it must be annoying, where has the speedo been going?
mcerd1
posted on 16/9/13 at 08:15 AM |
but think about it this way round - why compromise your choice of tyres just to get the speedo right ?
better to pick the right size of tyre for the handling of our car then make the speed match IMHO
how many gauges have you got at the moment ?
maybe a complete new (or second hand) set would cost about the same as one custom made one.....
[Edited on 16/9/2013 by mcerd1]
adithorp
posted on 16/9/13 at 08:31 AM |
Have to agreewith some of the others. To make up that sort of discrepancy with tyre sizes is going to be a big change needed.
Monster 7?
steve m
posted on 16/9/13 at 08:47 AM |
Pic of my dash is in my photos
The speedo is part of a set of gauges, and I am not changing them all, as for one I like the set up and they fit the dash perfectly
The company I used have refused to spend any more time on the speedo, as it seems to go back every year to be recalibrated
Or repaired as its stopped working
The cost of having it repaired again or converting it to electric, is not worth the hassle, or the 3 months off the road
with a big ugly hole in the dash
To be honest, if its a longish journey, I use a tomtom, and if local, just rely on deduct 10mph or drive slowly
[Edited on 16/9/13 by steve m]
Charlie_Zetec
posted on 16/9/13 at 09:29 AM |
Does the over-reading speedo mean the odometer is adding up faster than it should be as well, then?
If the company who supplied it are fed up of fixing/repairing/re-calibrating it each year, is t it in their best interest to figure out what's
wrong and remedy once and for all?!?
Charlie_Zetec
posted on 16/9/13 at 03:12 PM |
Coincidentally;
http://locostbuilders.co.uk/viewthread.php?tid=185258
Any use?
Scuzzle
posted on 16/9/13 at 03:24 PM |
I went digital with mine and it made life easy, you just press a button do what you know to be a mile at any speed and it sorts itself out. When I
had my analogue speedo it was a good bit out and I ended up using the sat nav and sticking tiny adhesive dots on 30,40,50 and 70 purely so I knew
where I was at in speed restricted areas.
I tried different speedo drive gears in the box but they never seemed to do the trick.
Scuzzle
posted on 16/9/13 at 03:25 PM |
Double post
[Edited on 16/9/13 by Scuzzle]
