Author: Subject: Spring Rates and ride quality
thepest
posted on 15/5/08 at 06:31 AM Reply With Quote
Is it possible to get the kind of shock that has 2 springs in it? (for a locost) At the moment I am running the GTS coilovers with 275lb/in in front and 180lb/in in the rear.
The ride is fine on good roads but since I drive on 70% not so good roads I was wondering if it is possible to "filter out" those tiny bumps. I don't drive through potholes but I can feel every imperfection in the road and the car + driver weighs 590kg.
The kind of shock I was looking for was something like THIS< br />
Or any other fix that could help I would appreciate.
indykid
posted on 15/5/08 at 07:40 AM Reply With Quote
the helper springs are only designed to keep the spring held against the seats at full extension and prevent dislocation. they're about 10lb/inch iirc.
i guess you could look at progressively wound springs or variable rate but they'll be expensive!
tom
paulf
posted on 15/5/08 at 08:36 AM Reply With Quote
The springs are to hard , i have 275 front and 160 rear and am considering going softer.I tried 180 on the back once but it was way to hard and i went back to the 160lb ones which may still be to hard.The fronts are also a bit hard but on my car the mountings are slightly different to book making them more up right.
Paul.
posted on 15/5/08 at 08:41 AM Reply With Quote
What wheel / tyre sizes are yo running?
Also, what pressure do you run the tyres at?
I run 195/50R15 tyres at 17.5psi front and 16psi rear on my Pinto engined Indy and found the lower the tyre pressure the beter for ride and grip.
(you may already have this element sorted though)
thepest
posted on 15/5/08 at 10:05 AM Reply With Quote
I am running 185 60 13's. 20psi Rear and 19psi front. Do you know where I can buy springs for my kind of shock?
posted on 15/5/08 at 12:13 PM Reply With Quote
Have you experimented with the tyre pressures?
I'd be tempted to lower them a bit and try the rear lower than the front.
Edit to say...
It's free to try and simple to reverse!
[Edited on 15/5/08 by nick205]
paulf
posted on 15/5/08 at 01:02 PM Reply With Quote
Rally design seem to be a good source of springs, they stock a wide range of strengths and sizes.
Paul.
MikeCapon
posted on 15/5/08 at 01:18 PM Reply With Quote
If you are looking for good quality springs at a reasonable price, available from stock, try these guys.
http://www.dfaulknersprings.co.uk/index.htm
If you ring you'll be speaking to Peter or Andy. Tell them I sent you and they'll look after you
Mike
www.shock-factory.co.uk
Chippy
posted on 15/5/08 at 04:07 PM Reply With Quote
Hi Phil, I used Faulkner, found them more than helpful. No good me giving you my spring rates, (350F & 325R). Cheers Ray
Linky
thepest
posted on 15/5/08 at 05:04 PM Reply With Quote
Thanks a lot! will give them a call.
mr henderson
posted on 15/5/08 at 05:17 PM Reply With Quote
It's a very light car with limited suspension travel. Are you sure that you aren't hoping for too much?
Part of the problem is the ratio of sprung to unsprung weight, which in the case of light cars like yours is quite high.
Are there any oppportunities in Malta to try a ride in a similar car, and see if it's any better.
Alternatively, consider a Bentley Continental, they have good ride and good handling, and are quite fast as well (also a LOT heavier)
