se7ensport
| posted on 25/6/11 at 09:17 PM |
Flywheel is from turbosport.net; £195 delivered, which is pretty good value & quality is spot on. It's designed to take the pinto clutch
which is a bonus as I'd already bought a heavy duty set up to go on the pinto.
[Edited on 25/6/11 by se7ensport]
Furyous
| posted on 27/6/11 at 07:45 AM |
I'll be watching this thread closely because I'm hoping to do a Duratec conversion in a Le Mans bonnet Fury later in the year. Would you
mind listing where you bought the parts from?
My main concern is fitting the engine under the bonnet without cutting holes. Does the Raceline sump reduce the height? Have you measured up
clearances?
Is this going on a Type 9 gearbox?
Make sure you take lots of photos, especially of any problems you have.
se7ensport
| posted on 27/6/11 at 11:32 AM |
clearances?
Engine mounts and exhaust manifold are from FastDan on here (and ebay), sump is direct from Raceline, bellhousing, pivot, clutch release arm and
bearing are from RWD motorsport, clutch plate, cover and flywheel bolts from Burtons, flywheel from turbosport.net
Sump reduces height by approx 3 inches and I'm using the type 9 box. It should fit in the space height wise (sloping bonnet doesnt help
though), the bit I'm unsure on is if the engine will sit too high or low on the mountings as they are designed for a locost chassis.
Tiger Super Six
| posted on 27/6/11 at 01:03 PM |
I have just fitted my Duratec in an Avon and had the problem of it sitting too high on the engine mounts. I had to get smaller rubbers (25mm) to drop
it down and it should all now fit.
Mark
Tiger Avon
neilp1
| posted on 27/6/11 at 07:00 PM |
Mark where did you get the smaller rubbers from?
Neil
se7ensport
| posted on 27/6/11 at 08:30 PM |
I'm going to put the request out there early: does anyone have a duratec spark map that they are willing to share??? Any format will work as
I'll manually convert it.
Alex
Tiger Super Six
| posted on 27/6/11 at 09:18 PM |
From a company called robush.co.uk it's 75mm diameter, 25mm thick and m12 threads coming out of it. Also has metal plates top and bottom.
Neil
Mark
Tiger Avon
FASTdan
| posted on 28/6/11 at 10:40 AM |
Alex
If you have any luck on this please let me know, we currently run a stock zetec one.
[Edited on 28/6/11 by FASTdan]
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Nitrogeno25
| posted on 28/6/11 at 05:41 PM |
Alex
I'm interested too, please let me know.
I read most uses a zetec map, but I don't know how much power they re getting.
Thanks.
se7ensport
| posted on 28/6/11 at 09:33 PM |
Duratec ignition map
okay, after an evening of surfing and messing about with emerald software I've got a copy of Duratec map based on the following spec (curtesy of
http://k80rum.co.uk/emerald_maps.aspx):
2,0 Duratec. 296o cams, Jenvey 45 TBs, grouped Bosch 155 968 injectors @ 3.7Bar in TBs, forged pistons, steel rods
I would expect the cams to change it slightly, but I should be a closer ignition map than a Zetec.
Duratec on left, Zetec on the right
[img]
  duratec v zetec
[/img]
Duratec ignition advance, once I've manually transposed these in to excel I'll post a link for others:
  duratec part 1
  duratec part 2
pjay
| posted on 29/6/11 at 12:20 PM |
Hi Alex - missed your request. Here's my current Spark Advance Table on a standard 2.0L Duratec. It's pretty basic but seems to run
well:
se7ensport
| posted on 29/6/11 at 12:35 PM |
Thanks pjay, interesting to see that yours is a much flatter map than the ones I found. I'm hoping a few others will post theirs so that they
can be tried and compared.
Alex
FASTdan
| posted on 29/6/11 at 12:43 PM |
[img]
  duratec v zetec
[/img]
  duratec part 1
  duratec part 2
Excellent work there!! Thats the one I had downloaded but then hit the stumbling block of not having the correct emerald software to read it -
although a very kind user on here sent me a copy I've not had chance to install or interrogate it yet.
big-vee-twin
| posted on 30/6/11 at 02:54 PM |
Watching with mucho interest
http://www.triangleltd.com
pjay
| posted on 30/6/11 at 04:37 PM |
Alex - yes it's pretty flat and I imagine quite conservative.
I decided to work on the basis of a maximum of 26 degrees advance because of the design of the combustion chamber/spark plug position etc. (although
I'm not an expert). The actual profile is pretty much straight out of MegaTune.
I'm hoping to get to a rolling road in the next couple of months and will see what modifications they make - but also interested to see what
else might be posted.
Pete
[Edited on 2/7/11 by pjay]
se7ensport
| posted on 2/7/11 at 06:59 PM |
Duratec oil filter
Now I've got the sump on it appears that I don't need to relocate my oil filter, I was expecting it to be the lowest point on the engine
but it isn't, by at least 10mm. Have Ford changed the design of the housing or is the filter shorter?
[img]
[/img]
[img]
[/img]
karlak
| posted on 3/7/11 at 10:51 AM |
[img]
[/img]
[img]
[/img]
Looks good. Is it a standard Duratec Filter.
I was ordering the raceline Filter housing tomorrow, but may hold off now till I get the sump fitted.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
big-vee-twin
| posted on 3/7/11 at 11:42 AM |
Just been out to look at mine, the standard Duratec oil filer housing has a heat exchanger built in on the ST150.
However looking at the engine in relation to the bottom chassis rail I think your filter will foul the rail even though it is above the sump level.
se7ensport
| posted on 3/7/11 at 07:35 PM |
Duratec oil filter part number
Its the standard filter from a 2009 Focus, FINIS number 1595247, part number 1S7E-6714-BA.
Luckily I don't have a chassis bar in the way that will foul it as it's a Stylus chassis rather than a seven, unfortunatley it also means
the engine mounts I bought from FastDan aren't going to fit as they will be too narrow. I'll be aligning the engine next weekend and
deciding what to do for the mounts, will probably be buying the plates from Dan and making the rest in situe (end result will mean my engine mounts
will be up for sale).
On a similar note the dipstick location on the Raceline sump isn't great, it comes out directly below the engine mounts, the only way to get a
dipstick in currently would be to drill a hole through the mount!!! Needless to say I'll be factoring in a mod to my mounts.
big-vee-twin
| posted on 3/7/11 at 08:22 PM |
Yep I found that out on my Dunnell sump, the solution was to cut a section of the dip stick tube out and replace with a rubber tube between the ends
to bend around the mount.
Better to mod the mount though.
se7ensport
| posted on 16/7/11 at 09:23 PM |
Well engine went in tonight (wooden engine mount on crank for time being), I'd been waiting on 4 bloody bolts for the alloy bellhousing for two
weeks! Pretty hard to track down as i needed M12x50 with 1.50 pitch thread, the original bolts were too short.
[img]
[/img]
[img]
[/img]
[img]
[/img]
I have a couple of challenges to overcome:
1. engine alignment is off to the passenger side due to drivers footwell, this means alternator and oil filter no longer fit! Some effort with a lump
hammer on the footwell and a bit of grinder action to the bellhousing might allow the alternator to fit again, but oil filter wont unless I move the
engine forward, easily doable but weight distribution suffers.
2. think a new bonnet bulge may be needed, although final engine height is yet to be decided up on.
[img]
[/img]
[img]
[/img]
radom
| posted on 17/7/11 at 06:49 AM |
Alex
at the bottom of the page
http://www.zetecinside.com/xr2/dtas80_tech.shtml
big-vee-twin
| posted on 17/7/11 at 07:45 AM |
You could consider a low profile Duratec cam cover to see if that allows your bonnet to fit.
Not the cheapest out there but may save you some hassle with the bonnet
se7ensport
| posted on 17/7/11 at 08:59 AM |
Alex
Thats brilliant, thanks for pointing that out, I'd been through his site before and found other info, but missed that!
[img]
[/img]
Engine info (198.9bhp@7000rpm):
2.0 L Duratec
IW030 Injectors
Tony Law manifold
4-2-1 Exhaust
Standard Engine Internals
Standard 3bar Fuel Pressure
Titan Roller Barrels
Sequential COP and Injectors
Coil per plug OFF
Twin Spark ON
Sequential Injection OFF
source: http://www.zetecinside.com/xr2/dtas80_tech.shtml
[Edited on 17/7/11 by se7ensport]
se7ensport
| posted on 17/7/11 at 09:23 AM |
Would be good if they provided some details about it's height... using the cam sensor as a comparison it does look lower overall, but the height
of the COP might be a problem.
[img]
[/img]
