mad-butcher
posted on 1/5/12 at 05:55 PM |
Great idea, but doubt if it would work on my indy, sure I wouldn't have any clearance under my road wheels with my current protech suspension
units by the time they are fully extended
puma931
posted on 1/5/12 at 06:01 PM |
quote: Originally posted by PAUL FISHER
Found it here.
Westfield Kit car Track car | eBay
Great... comes with a free car
SteveWalker
posted on 1/5/12 at 06:47 PM |
quote: Originally posted by puma931
Andy996tt - Looks great, where did you get the pictures from, as it would be good to find out where the owner purchansed the parts.
Mathew
There are plenty of places to get trailer suspension units, mounting plates, etc. Just two examples: Towsure or Indespension.
For heavier cars you can also get braked units, sliding hitch and brake cables, but they start to get expensive, hence people using caravan parts.
Steve W.
puma931
posted on 2/5/12 at 09:29 AM |
Any ideas on the size of the 'trailer' wheels?
I have spotted some trailer build packs on ebay for £270 + delivery, which contain most of the parts, but I am not sure what trailer wheel size to go
for, plus how much drop will there be on the suspension (car is at my mates garage so I can't check - locost race car)?
tasmod
posted on 2/5/12 at 04:50 PM |
That's a good looking idea. Once bolted up no need to tie down, bolt on axles minus wheels use a quicklift type jack and bolt on wheels.
Simples.
I think i would be inclined to make a bolt up 'cross' bar utilising the plate method to move the wheels out a bit and clear the
exhaust.
Maybe even make it a T bar incorporating the drawbar.
Unbraked trailer limit is 750kg overall. After that brakes required.
Hmmmm.
Rob
mad4x4
posted on 2/5/12 at 06:02 PM |
I would be building the Basic frame for the Trailer and then Tie down rather than "bolt to car" Could make a simplet 3" box
Frame that holds every thing square and a Few Pins or Clips under the car place correctly to make with tralier.
In the yatching world they use this with the boat of the light "launch trolley" in out case the Car could be the Launch Trolley....
Could easily fit Brakes to this if it was required due to a "heavy" build
[Edited on 2/505/12 by mad4x4]
Scot's do it better in Kilts.
puma931
posted on 21/5/12 at 08:16 AM |
I bought all the bits from ebay (£330 including jockey wheen and wide light board with fogs)..... just need to fit them and make up the front arm.
I was thinking of mounting the front arm under both engine mounts (welding mounting plates to the underside of the chassis. The floor on my car is
made of steel so the suspenson units will bolt directly onto the floor. I will take some pictures when I get around to it.
owelly
posted on 21/5/12 at 08:25 AM |
Unless your floor is at least 8mm thick I think you'd be better off mounting off the chassis!
http://www.ppcmag.co.uk
puma931
posted on 1/7/12 at 09:45 PM |
On Saturday I welded the plates to the floor (for the trailing arms) and now just need to figure out where to fix the tow hitch arm.... probably off
the chassis near the engine mounts. Will take some pics when finished. Cool trailer solution
owelly
posted on 1/7/12 at 10:04 PM |
Velcro. Very quick and suprisingly strong......
puma931
posted on 2/7/12 at 08:52 AM |
;-) very good..... I think I will stick to welds and bolts
motorcycle_mayhem
posted on 2/7/12 at 10:16 AM |
What a superb idea!
For those (few) of us with no space/money/serious tow cars - a bit of welding and I've got a means of carefully getting the car back home after
a damaging track day. No trailers, no hassle, just this kit in the back of the wife's MK1 Mundaneo in case things go wrong on the circuit.
puma931
posted on 16/7/12 at 09:34 AM |
Latest picture of my 6 wheeler....
Welded plates to the floor (chassis/rollcage section) and just need to weld some more plates to the front (near sump/suspension arms) for the arm/tow
hitch.
IMO this is an excellent trailer solution that will take about 10 min to fit / remove
[Edited on 16/7/12 by puma931]
puma931
posted on 22/8/12 at 02:46 PM |
Got my car home :-)
The trailer solution works and it towed very well behind my 318d.
Now it is at home I can finish off the to do list and hopefully I will get it on track soon.
Happy days.
number-1
posted on 26/8/12 at 09:57 AM |
That looks like a great idea. did you find the balance point of the car to weld the wheel mounting plates to or was it a guess? Any pics of the
underside after you welded the plates on?
N1
abarth695
posted on 26/8/12 at 04:06 PM |
I am a bit lost here, why have the added wheels ? Can't the existing rear wheels be used such as an A Frame but with the front one's off
the ground or is that too much weight for the tow bar?
number-1
posted on 26/8/12 at 04:48 PM |
I think if you leave the kit cars wheels on the ground the kit car has to be insured. By taking the kit cars wheels off the ground it doesnt need
insurance....i think?
MakeEverything
posted on 27/8/12 at 12:18 PM |
or Tax...
Kindest Regards,
Richard.
posted on 27/8/12 at 03:02 PM |
You would have far too much nose weight using the cars rear wheels, tow bars usually want 50 - 100kgs, with a cec you'd see about 300kgs.
Also, its well known to plod that if the cars wheels are on the ground then its more likely to be illegal, at least with the bolt on wheels it *looks*
like its legal (i dont actually think it is, but i also dont care anyway).
puma931
posted on 28/8/12 at 07:54 AM |
The plates were welded under the front section of the roll cage (nice and strong), which gives about 100kg weight on the front. I will take some
pictures later in the week of the plates and the connection points for the tow hitch. The car is not road legal, so it has to be lifted off the road,
effectively the underside of the car becomes a trailer. I went for this solutiuon as I don't have space for a trailer and it only takes 30 min
to fit using manual tools, scissor jack and 2 axle stands (much quicker when I get an impact gun and low profile trolley jack).
N1
