oldtimer
posted on 10/11/08 at 02:09 PM |
Rose jointed suspension-that bad on the road?
Rose joints - the part built chassis I have came with rose joints on the suspension.
So....
What are they like under road use??feed-back from actual users please.
How long do they last??
Do people fit boots over them for weather protection?
As it'll be the occasional trackday and maybe the occasional hill climb should I swap for bushes now??
I've all my bits now soit's time to actually put the stuff together.
nitram38
posted on 10/11/08 at 02:17 PM |
I'ved used them on the F1-2 without any problems, they are also going on the Motaleira. Atom use them.
No boots on mine, I just check them from time to time.
2300 miles on the F1-2 and they are still good.
Less flex on your suspension means more accurate set up and feedback while driving.
Opinions will differ.....I like them....others won't. Downside is they are more expensive in the long run.
A good cheap supplier is Mcgill motorsports. Look them up on ebay.
[Edited on 10/11/2008 by nitram38]
Mr Whippy
posted on 10/11/08 at 02:50 PM |
just the fact that folk seem impressed with them if they do a few thousand where as I'd expect many tens of thousands from a normal joint makes
my mind up. Also our roads are so awful the thought of feeling every imperfection hardly appeals. Fine for racing though when you have money to burn.
scutter
posted on 10/11/08 at 02:58 PM |
My rear suspension is fully rose jointed, really good feedback through your a*se, mind i've a padded roadster 7 seat, don't know what
they'd be like with some skinny fibreglass shells.
ATB Dan.
Mr Whippy
posted on 10/11/08 at 03:06 PM |
ATB Dan.
well you've no doubt heard of ' vibration white finger syndrome'...
Flamez
posted on 10/11/08 at 03:11 PM |
mmm. my mac [in build] uses them on front top wishbones and 1/2 rear bottom wishbones. They do I guess allow more finite adjustments? as for ride etc
I'll leave that to others for now.
my build mac1motorsports
Paul TigerB6
posted on 10/11/08 at 03:48 PM |
The original poster asked for opinions off people who have used rose jointed suspension. How many miles have you done in a rose jointed car??
lsdweb
posted on 10/11/08 at 03:52 PM |
I'd go rose jointed every time for the precise feel and ability to adjust.
Totally different use for me though - not a lot of road mileage.
I'd also recommend McGill Motorsport - spot on with quality and excellent delivery times!
Wyn
mr henderson
posted on 10/11/08 at 03:53 PM |
Well, to be fair to Mr W, it isn't exactly a fair question from the OP. If he asks to receive ony responses from people who actually use rose
joints on a road car then his results are going to be badly skewed as the resaonable presumption is that RJ users would be unlikely to say that they
were doing the wrong thing
John
Paul TigerB6
posted on 10/11/08 at 04:05 PM |
John
Why isnt it fair to ask for the opinion of people who have actually done it over general concencus of the masses?? I'd take their opinion over
heresay every time so think its a reasonable question to ask - i am guessing that the OP expected some negative comments from people with no 1st hand
experience.
We see the same thing when it comes to BEC vs CEC. I bet many of the derogatory comments re BECs come from people who have never been in one.
Anyway, IMHO if you dont mind the noticably harsher ride and the additional maintainance then i'd also use rose jointed suspension on a car that
is going to be used on track occasionally. For a pure road car i doubt you would get close enough to the limits to really benefit from the more
precise feel / setup.
mr henderson
posted on 10/11/08 at 04:15 PM |
I think I used the wrong word when I said 'fair'. Perhaps 'useful' would have been better.
Sometimes people don't actually need to do the exact thing that is being asked about to have a viable opinion on the subject. For instance, I
have never had any body piercings or tattoos, and if someone was asking whether they should make a visit to a tattoo parlour, then I think my opinion
would be equally valid as that of somebody who had had lots
John
contaminated
posted on 10/11/08 at 04:21 PM |
7000 miles on my rose joints with no issues.
oldtimer
posted on 10/11/08 at 04:31 PM |
My request for user only input was due to the fact that I see this as a technical/practical issue rather than opinion/aesthetics.
Negative and positive feedback about rose joint use happily received.
Regards
Martin
Paul TigerB6
posted on 10/11/08 at 05:07 PM |
Oh well i'll have to admit defeat on the understanding of that point of view when it comes to specific technical issues. I'd always put
more weight on genuine experience over speculation
russbost
posted on 10/11/08 at 05:56 PM |
I have them on my original Furore as it has the Formula Ford suspension from the "donor", for the new car I have gone to poly bushes
purely for cost reasons. I don't think you would feel the difference between poly bushes & rose joints on the road. In terms of life
I've got no problems on the original car & these are all old joints which had been used for racing (in the '70's) dry stored for
years then put back into use, they've done about 1500 road miles, you hear of poly bushes wearing out (tho' I think this is largely due to
incorrect assembly) just as rose joints do, given the sort of mileage these types of car usually cover I doubt you'll be wearing many out.
My advice would be decide which you want to go with based on cost/performance issues rather than longevity.
scutter
posted on 10/11/08 at 06:28 PM |
ATB Dan.
Mr Whippy, I think you'll find it's my thumb what's normally there.
I think i'm getting close to 6000miles on the rose joints a slight bit of play in the panhard rod, I can live with a tenner of joints over
5000miles.
ATB Dan.
MikeR
posted on 10/11/08 at 10:09 PM |
mine hasn't turned a wheel yet but has full rose jointed pan hard rod and half rose rear trailing links (the car side is poly bush, the axle
rose).
Hopefully i'll have something close to the best of all worlds...... some time in 2020 when i get on the road.
rubberburner
posted on 11/11/08 at 07:33 AM |
Ive got a BEC, covered some 7000km over the last three years with an even split between road and track. Its fully rose jointed. Ive changed two
joints, which where old from the start, the rest is fine. Im using grease filled rubber boots on the joints to keep them clean and well lubricated.
Comfortwise I think its ok for the mileage and type of driving Im doing on the road, a quick sunday morning journey when the sun is shining is
extremly satisfying, when it comes to feel on the track I simply love it.
If your focus will be road usage I would recommend bushes, but if track running is your game, rose joints is the way to go.
Used as a daily transport to work, whatever weather, I would go for a more comfortable type of vehicle though.
Thats my experience anyway.
[Edited on 11/11/08 by rubberburner]
posted on 11/11/08 at 01:08 PM |
Like Flamez, we have rose joints fitted on our front top wishbones and half lower rear wishbones. We use them for the accurate adjustability they give
for setup. We haven't noticed any difference in the overall ride quality. The rubber boots we got with them haven't been fitted because we
felt they would be much easier to check and service without them.
Can't really comment on the longevity though cos we've had them fitted for about 6 months and only covered about 1,000 miles on them.
Phil
