Author: Subject: Brake hose
bassett
posted on 10/11/08 at 10:02 PM Reply With Quote
Brake hose
Hi, Im assuming you can use rubber hose for linking a resevoir to copper brake lines as its mentioned in my builders manual but does anyone know where i can get some preferably online as all i can find is braided/stainless flexi hose kits where as i want a rubber metre of 8mm ID?
Adam
MikeR
posted on 10/11/08 at 10:11 PM Reply With Quote
merlin motorsport do it. I've not found anyone cheaper - make sure what ever you buy is marked up for use with brake fluid or you have the relevent spec sheet with you for SVA.
001Ben
posted on 10/11/08 at 10:16 PM Reply With Quote
not online but try halfords or your local autofactors
iank
posted on 11/11/08 at 07:20 AM Reply With Quote
Fiat Seicento hoses.
See http://www.locostbuilders.co.uk/viewthread.php?tid=72701
Edit: you can't just use any hose because brake fluid melts it. Even some stuff supposedly correctly marked can start to weep if you use the "wrong" fluid.
[Edited on 11/11/08 by iank]
Anonymous
stuart_g
posted on 11/11/08 at 07:49 AM Reply With Quote
Merlin motorsport is the place to get it, if you ask them they will also send you the spec sheet that your SVA tester may want to look at.
Rob WM
posted on 11/11/08 at 09:29 AM Reply With Quote
Kevin at Tifosi does it I think. May have to order over the phone but he can post.
pewe
posted on 11/11/08 at 12:40 PM Reply With Quote
Brian at www.bgcmotorsport.co.uk normally turns it round same day and prices are reasonable. Cheers, Pewe
bassett
posted on 11/11/08 at 12:53 PM Reply With Quote
Cheers guys, not on there website but a quick call to merlin motorsport and they do, do it. Works out 100mx60p and i only need a bit so very cheap.
Adam
