Rob WM
posted on 13/11/08 at 09:12 AM |
R1 Starting problems
Morning All.
Excited but sadened all at the same time! Last night I filled the cooling system with the recommend coolant as Malc's instruction. I changed the
oil filter and refilled the oil with the approved oil. I removed all the spark plugs and cleaned them as they are almost new by the look of them. I
then turned the engine manually to distribute the oil around the cylinders etc. Now the moment of truth. I have joined the sidestand switch and the
clutch swith. I have twisted the imobilizer together and joined the run switch together. I turned the key (ignition switch) and then shorted the start
button wire and........ Nothing not even the fuel pump or starter. I will of cause being entering the garage again tonight however before I do is
there anything obvious that I should be checking?
Cheers fellas
Dangle_kt
posted on 13/11/08 at 09:17 AM |
when the igintion comes on (before pressing start) you should here the fuel pump prime itself, it whirrs, then clicks a few times as it gets up to
operating pressure.
Do you have your dash in? Do any lights come on?
Is the engine in gear? Some bike engines need the bike in neutral.
Some have a clutch switch too, has that been wired in?
Rob WM
posted on 13/11/08 at 09:24 AM |
The engine was in neutral. I am going to install the R1 clocks but have not extened this wiring yet so it is just plugged in on the loom resting on
the tyre.
I have shorted the clutch switch anyway (providing I have correctly identified the wires!)
Knowing the fuel pump clicks in first is a help though. Do any lights on the dash come on?
If any of these switches are not shorted will the engine be 'dead' or will I still get the fuel pump etc?
ko_racer
posted on 13/11/08 at 09:28 AM |
which model r1 do you have?
The dash will give you error codes on the injection models which will reveal all.
If the dash isn't working you've probably not joined the ignition wires.
You can test it by unplugging the power and plugging back in. It should do a self test on power up, the reve counter should go up and back down
again.
[Edited on 13/11/08 by ko_racer]
r1_pete
posted on 13/11/08 at 09:33 AM |
What have you done with the exup valve, on the bike it cycles when you first switch on to clean itself, there is a bypass which someone on here should
be able to help with.....
smart51
posted on 13/11/08 at 09:36 AM |
If it doesn't turn over then you have a wiring problem. I have posted a 98 R1 wiring diagram on here if you do a search. What year of R1
engine do you have?
Rob WM
posted on 13/11/08 at 12:11 PM |
I have a 2006 R1. The Exup valve is still connected (leaving getting rid until I know it all works!)
Are the ignition wires the two larger red ones in the main switch 1 (on wiring diagram)?
I will try all tonight, just wanted to know the common faults that people have to give me a clue as to what to look for. It also helps know what
should fire up and at what point! The info on the dash should help I will check that tonight as well. I will let you know.
Thanks again
ko_racer
posted on 13/11/08 at 01:25 PM |
Right, so you have the 5VY.
If you got the engine from Malc at yorkshire engines, he would have supplied the US loom and ecu which gets around the immobilisor problem.
Make sure you have the following connected:
Thick White Connector:
Brown/Blue
Solid Red (Ignition - On/Off )
Red Connector
Blue/Yellow
Blue/Black Join
Blue 6 Pin Connector
Red/White (Run Switch)
Red/Black Join
Black (Starter Switch)
Black/White Momentary Join
Blue Connector
Blue Black (Side Stand Switch)
Black Join
White 10 Pin Connector
Black/Yellow Join
Blue/Yellow (Clutch Switch)
Make sure the big Red Main fuse is OK (50A from memory)
Make sure the other fuses in the fuse box are ok.
Make sure the Crank Position Sensor on the right hand side of the engine below oil pump cover housing is ok and wiring is undamaged. The wiring for
this is easily damaged if a bike is dropped and the motor won't run without this. The dash will tell you if any sensors have broken wires. The
workshop manual gives you what all the codes mean. Let me know if you need a copy.
Make sure the tilt switch is the right way up if you've not glued it or replaced it with a resistor (470 ohm) (Blue to yellow/green) The switch
is latching so once you've activated it it's on until you turn the ign off.
If you aren't using the fuel level sensor use a 470 ohm resistor on the Black to Green/White wires on the fuel pump connector. This will turn
the light off on the dash.
The start inhibitor relay should click when you turn on the ignition and the fuel pump should prime for a few seconds.
The start inhibitor actually has two relays inside so both should click if all is ok.
As you have the dash it should be easy to track down what's stopping it from starting. I spent ages tracking mine down to a snapped wire on the
crank pos sensor when I first started mine. Was obvious once I saw it though.
If you need any guidance drop me a mail at keith@koracing.co.uk, I'll give you my mobile no and talk you though it.
Rob WM
posted on 13/11/08 at 01:33 PM |
Keith you are a star!
I will try and get the checks sorted tonight before I give you an e-mail.
I thought the loom must be the US version as some of the coloured wires were confusing me!
I am by no means an expert on wiring so all this is good stuff.
Thanks again.
adithorp
posted on 13/11/08 at 02:16 PM |
All the info you should need to get the engine running if that ^^^ doesn't help is here...
http://www.robcollingridge.com/kitcar/design/engine/electrics.html
adrian
http://jpsc.org.uk/forum/
marc n
posted on 14/11/08 at 07:52 PM |
malcs your man, very helpfull and he knows his beans
i am still trying to workout why its in the mnr section when you say your building an mk r on your profile![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
best regards
marc
please email rather than u2u
chrismnrltd@btinternet.com
