Author: Subject: what gasket do i use on ali webber inlet on 2.0 zetec ?
indyian
posted on 18/11/08 at 04:06 PM Reply With Quote
as above what gasket do i need to use on the inlet for the zetec i using webers the inlet that was removed was plastic and uses rubber rings wich cant be used any ideas whats everyone else used
many thanks ian
posted on 18/11/08 at 04:19 PM Reply With Quote
get a silvertop inlet gasket, from a 94 Mondeo for example, check the port sizes are the same and that should do ya.
Plastic inlet? Is it a ST170 engine??
SeaBass
posted on 18/11/08 at 04:33 PM Reply With Quote
A suitable gasket is freely available - I think it's probably the one coozer has mentioned... It's aluminium with rubber bonded on as far as I remember... I've got mine from Burton Power in the past. It's about 20 notes though.
Here it is...
JC
[Edited on 18/11/08 by SeaBass]
Dusty
posted on 18/11/08 at 08:27 PM Reply With Quote
I used a smear of silicon goo.
indyian
posted on 19/11/08 at 12:37 AM Reply With Quote
thanks for the help
