James
posted on 20/1/04 at 05:40 PM |
Ignition Module/Amplifiers
Please could someone confirm that the Ignition Module/Amplifier (I presume they're the same thing!) is different on an EFI car than that on a
carb' car.
I just want to confirm that I can't use the module that came with my EFI Pinto donor now that I'm running it with carbs.
Thanks,
James
TPG
posted on 20/1/04 at 05:56 PM |
somewhere,may be on here.I,ve seen and read that it is a good common modification to fit the efi/electronic ignition dizzy to pintos when running
carbs.It could be classic ford or something like that.Have a root 'round cause it does away with pionts and condenser.
theconrodkid
posted on 20/1/04 at 06:11 PM |
the dizzy on efi is diffo and needs amp that runs efi as well,carbed ones just have amp on side of dizzy n coil
who cares who wins
pass the pork pies
ady8077
posted on 20/1/04 at 06:29 PM |
Hi
The dizzy's different too on an efi pinto, it hasn't got mech advance
Easyist way is to get a dizzy coil and amp off a 1.6 ohc sierra, theres only 5 wires and the dizzy got mech advance
Hope this helps
Adrian
Dusty
posted on 20/1/04 at 07:05 PM |
Sierra pre 85 2.0L carbed or 1.6L, (not economy) has six wire inductive module with Bosch dizzy and mechanical advance and is easiest IMHO. Pics in
my photo archive.
James
posted on 21/1/04 at 11:29 AM |
Doh! I thought I was doing it the simple way!
Thanks for the info everyone.
Ned kindly gave me his dizzy and coil from his 2.0 carb' Pinto. So I just assumed if I got the right amp' it would be a straight swap!
Interestingly the dizzy has no vacuum advance and appears identical to the dizzy from my EFI Pinto!
Do I really need one with an advance if the donor didn't have one?
Thanks,
James
theconrodkid
posted on 21/1/04 at 12:37 PM |
james,is there a black box on t side of dizzy?that is the amp,if it only has 3 wires it has a remote amp,ive got wiring diags for all types
who cares who wins
pass the pork pies
James
posted on 21/1/04 at 01:18 PM |
No, no black box on dizzy.
Bob's going to sell me an amp' tho. It's just a connector for it I need now.
Does the amp' need to be specifically off a 2.0 litre? Or are they all the same?
As you can tell I don't really know what they are for!
James
theconrodkid
posted on 21/1/04 at 04:07 PM |
amp needs to be matched to dizzy,bet some pics and ill let ya know
who cares who wins
pass the pork pies
bob
posted on 21/1/04 at 06:59 PM |
James
The amp is free of charge
James
posted on 22/1/04 at 01:19 PM |
Thanks mate- that's good of you!
Just wish i wasn't such a muppet and knew if it'd work or not!
Oh well, I'll wire it up and see what happens!
James
ned
posted on 22/1/04 at 03:26 PM |
for info, that dizzy was off a d reg 2.0 pinto car. probably already told you that james. anyway, if it helps etc etc..
Ned.
beware, I've got yellow skin
bob
posted on 22/1/04 at 05:07 PM |
I think i have another dizzy knocking about in the garage that matches the amp i have,i'll bring it to newlands on the 1st anyhow.
