Author: Subject: CO2 cylinders - public service announcement (for tightwads)
zilspeed
posted on 1/12/08 at 07:16 PM Reply With Quote
This information is particularly useful for those in the Glasgow area, but slightly useful for the rest of you too.
Here is the official Zil method of "how to get your hands on a cylinder of CO2 without having to nick a cylinder or ingratiating yourself with a landlord and get it filled for under £250."
First - get hold of the Cylinder, that'll cost you £37.50 filled from here.
http://gascylindersuk.co.uk/store/catalog/product_info.php?products_id= 30
If you're local to them, they deliver it filled, if you're not local, it's delivered empty and they arrange filling locally.
This is the Glasgow only bit.
For subsequent fills go here.
http://www.m-s-fireprotection.co.uk/refilling.htm
Was in today and they quoted me £7 to fill a cylinder.
So, the cylinder has cost you £30 delivered. For that you pretty much get to keep it for as long as you want without thinking of all those rental fees you're clocking up. Refills (which will probably be annual) will cost you £7.
There's probably a better way, but if you're like me and you're that tight that you squeak when you walk, then this is probably the answer.
Note : - The cylinder description is as follows.
Refurbished 14lb carbon dioxide cylinders, pressure tested, new valve, painted in black, shoulder of the cylinder any colour, valve handle with logo printed.
Doesn't seem that bad a deal to me.
If you already knew all of the above, achh - it was only five minutes of your time.
[Edited on 1/12/08 by zilspeed]
posted on 1/12/08 at 07:23 PM Reply With Quote
Bought mine from the local beer wholesaler (The Beerseller) for £15 non returnable.
zilspeed
posted on 1/12/08 at 07:26 PM Reply With Quote
I did search for local sellers up here, but couldn't find any.
I know nothing of these things, maybe BOC have it wrapped up in these parts.. Haven't a clue.
Anyway- Cozzer's solution is even better.
zenarcher
posted on 1/12/08 at 08:35 PM Reply With Quote
Thanks for the links.
posted on 1/12/08 at 08:49 PM Reply With Quote
Forgot to add I also picked up 88 pints of Fosters while I was there, all in a handy stainless barrel
paulf
posted on 1/12/08 at 09:13 PM Reply With Quote
My local brewery supplier used to sell them for about a tenner with no deposit ,expecting you to take it back when empty.Local people all found out and used to get them and have them refilled by the local fire extinguisher company until the brewerys threatened them with legal action for theft of cylinders.They now sell an extinguisher with a screwdown valve in place of the lever and charge about £10 to refill it.
I have been using some extinguishers I picked up cheap and just cable tying the lever down , a normal regulator screws in in place of the hose.
Paul.
zilspeed
posted on 1/12/08 at 09:17 PM Reply With Quote
How much do you get out of a 5Kg extinguisher ?
locoboy
posted on 1/12/08 at 09:56 PM Reply With Quote
5 Kilos.........
Locoboy
dave1888
posted on 1/12/08 at 10:24 PM Reply With Quote
5 Kilos.........
You asked for that one John
zilspeed
posted on 1/12/08 at 10:36 PM Reply With Quote
And I got it - square up the Ronson.
I was thinking more of welding time...
