Author: Subject: Parts Left.. Zetec, Manifold, Starter etc
mikeb
posted on 16/12/08 at 11:27 AM Reply With Quote
Well after my bargain clear out, still brings a tear to my eye I still have the following parts left.
2.0 Zetec early silvertop ~88k, sump modified £140. Can run on carbs for sva due to age. box full of ancillaries as it was a complete engine with ecu and wiring. Current sat on engine stand and has been cleaned ready for paint.
Zetec Inlet Flange (shorttrack) £10
Type 9 gearbox £40, no gear stick or clutch arm thingy
Pedal kit for haynes £22 SOLD
zetec engine mounts £10 SOLD
Wing stay kit from 3ge £10 (believe this contains all parts to make wingstays some bits were supplied already welded but I've never got them out of the bag!). SOLD
Zetec Mild Steel Exhaust Manifold, needs the primaries extending to suit roadster chassis, I have the metal to extend and a manifold plate. Absolute bargain at £65.
Starter Motor £20, Recent refurb to suite zetec to type 9, thinks it a CVH one I did the research and this is the one needed for zetecs.
Bottom Ball Joints £10 for the pair
Zetec Cooling Pipework £15, a selection of hard and soft pipes from a westfield zetec including header tank. Probably had enough parts to get the zetec plumbed in on a budget. Collection only too odd shape to post!
Rear Chassis tubes, bent to shape, tacked on and removed due to a Triton rear end. Come and pic them up for £8. to big to post cheaply.
Engine spigot bearing (supports the type 9 input shaft) £2 SOLD
I think thats about it.
Preference made if you can collect parts, if your installing a zee you'll need most of the bits above. Dont really want to post the bigger items. Postage to be added to above prices.
Mike
[Edited on 16/12/08 by mikeb]
tcc21racing
posted on 16/12/08 at 09:04 PM Reply With Quote
u2u sent
tjoh84
posted on 16/12/08 at 09:41 PM Reply With Quote
u2u sent
Stantman
posted on 18/12/08 at 08:35 AM Reply With Quote
Starter motor
Having trouble with zetec to type 9 clearance for starter motors (despite sump having been modified and fitted to a friends car previously though then on an MT75).
Intereseted dependant on diameter of starters main body.
? postage ?
big vern
posted on 24/12/08 at 11:25 AM Reply With Quote
u2u sent
