Author: Subject: Cheap Zetec conversion?
chrisg
posted on 26/1/04 at 08:52 PM Reply With Quote
This months "Custom Car" magazine carries a feature on a rather nice Ford anglia rod, which runs quite an interesting engine.
It's a Ford Zetec running on a pair of landrover 2.2 webbers with anti deiseling valves(?) on a homemade manifold and a custom made distributor drive to a orion CVH distributor, belt driven from the exhaust cam.
The article doesn't give any more details, anyone know more?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
ady8077
posted on 26/1/04 at 09:10 PM Reply With Quote
Hi Chris
I've not seen this type of conversion before, but i have seen a zetec runing webers and using the ign mod off a 1.8 cvh out af a Sierra. Apparently the 1.8 uses the same flywheel pick up as the Zetec
Adrian
Stu16v
posted on 26/1/04 at 09:33 PM Reply With Quote
The dizzy idea is very similar to how Vauxhall ran the dizzy on the Manta 1.8's.....
david walker
posted on 27/1/04 at 10:37 PM Reply With Quote
Originally posted by ady8077
Hi Chris
Adrian
No the Sierra runs its pick up off the front crankshaft pulley, but you are nearly right, I have posted details before of how to build a crank triggered ignition system using an early Fiesta HCS system combined with a modified Sierra pulley adapted to whatever engine you wish. Ignition map is a compromise but I defy you to tell on the road! All for about 20 quid.
The pics of the Landrover show some nice engineering but I doubt the performance ability of the carbs (at least compared to others that are cheaply avaialble)
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
