New Topic New Reply
Author: Subject: changing the pdc on alloy wheels who can do it.
thunderace
posted on 23/12/08 at 03:06 PM Reply With Quote
hi im looking for someone in scotland or some advice on how to change the pdc on my alloys.(i can redrill the whole easy its the tapered bit im not sure of.)
Mr Whippy
posted on 23/12/08 at 03:12 PM Reply With Quote
a good machine shop will have everything needed for this simple task. Use yell.com and look up machine shop etc like this one below -
Sprite Engineering Ltd
10, Lenziemill Rd, Cumbernauld, Glasgow, Lanarkshire G67 2RL
Tel: 01236 457970
Classification: Engineering Machine Shops
carpmart
posted on 23/12/08 at 03:16 PM Reply With Quote
Without appearing pedantic (I hope!), its PCD not PDC.
From memory, it stands for Pitched Circle Diameter!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Bear in mind that the centre bore size may also be different.
Phil
chrisg
posted on 23/12/08 at 03:18 PM Reply With Quote
Make sure that the bit you want to drill is as thick as where the original holes are - some alloys are thickened out around the holes.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Mr Whippy
posted on 23/12/08 at 03:33 PM Reply With Quote
nice wheels btw
MakeEverything
I wouldnt do it. I would get different wheels with the multiple PCD or ford PCD. The wheels are the first thing that will hit potholes, speed bumps etc, and there is no give between the wheel and the hub.
Kindest Regards,
Richard.
mr_pr
posted on 23/12/08 at 03:45 PM Reply With Quote
Had a friend do it for some alloys for his corsa. Insurance companies wouldn't touch him because of it.
If you don't declare it then you might end up like the recent landy driver in the news!
My Build Progress
thunderace
posted on 23/12/08 at 03:56 PM Reply With Quote
Tel: 01236 457970
LOL I KNOW THE OLD GUY THATS IS Sprite Engineering
mcerd1
posted on 23/12/08 at 04:36 PM Reply With Quote
Have you ever thought it might be easier to modify the hubs ?
also what size are the centre bores (ford are 63.4mm I think)
not quite - its "Pitch Circle Diameter"
[Edited on 23/12/08 by mcerd1]
COREdevelopments
posted on 23/12/08 at 07:27 PM Reply With Quote
i had my rear hubs re-drilled to accept ford pcd. used a local engineer and he done a spot on job, i wouldnt drill them out if i were you, get a good machineshop to do it.
atb
Rob
posted on 23/12/08 at 09:40 PM Reply With Quote
Re-drilling the hubs and fitting new studs has to be the way to go mechanically and cosmetically. A simpler job, but still best done with the correct equipment.
Alan B
posted on 30/12/08 at 02:06 PM Reply With Quote
And without appearing pedantic likewise it's pitch not pitched.....
New Topic New Reply
