Author: Subject: Sierra rear hub nut size
bassett
posted on 2/1/09 at 12:12 PM Reply With Quote
Hi, does anyone know the socket size for a sierra rear hub nut?(with discs if it makes a difference)
Flamez
posted on 2/1/09 at 12:16 PM Reply With Quote
46mm and they have opposite threads.They tighten towards the front of the car.
You will need a long lever to undo them....
my build mac1motorsports
bilbo
posted on 2/1/09 at 12:17 PM Reply With Quote
Off the top of my head 41mm springs to mind. I'll just go and check.
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
eznfrank
posted on 2/1/09 at 12:18 PM Reply With Quote
41mm
There's one on Ebay - linky
bilbo
posted on 2/1/09 at 12:19 PM Reply With Quote
Yep, mine are 41mm. It was originally a drum set up though, so not sure if the disk ones are different?
eznfrank
posted on 2/1/09 at 12:22 PM Reply With Quote
Mine are discs and they're 41 too.
bassett
posted on 2/1/09 at 12:24 PM Reply With Quote
Thanks, will go with the 41mm one as i had measured it but ours is as old as the sierra it came off and isnt in the best condition so wanted to be sure.
cheers
[Edited on 2/1/09 by bassett]
John.Taylor
posted on 2/1/09 at 01:02 PM Reply With Quote
Mine's a 41mm x 3/4" Draper socket which I had to buy a 1m x 3/4" braker bar for but this didn't provide enough leverage so I went to BSS plumbing supplies and bought a 3m length of steel pipe to go over the breaker bar. Once I'd attached a towing rope between my Sierra donor and own car to stop the Sierra moving with the torque of the breaker, all the nuts came loose without a fuss.
minitici
posted on 2/1/09 at 01:20 PM Reply With Quote
Yes 41mm
wilkingj
posted on 4/1/09 at 02:38 PM Reply With Quote
Usually a bitch to shift.
I welded a bit of box to a scrap disc and then levered it against a tube inserted in the box section.
It still bent a decent bar in my socket set.
But then I did have a 3metre bit of scaffold on it!
Made it dead easy, and the old disc was scrap anyway!
Are your Nuts Too Tight?
[Edited on 4/1/2009 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
