Author: Subject: Best crushtube to polybush grease ?
cloudy
posted on 5/1/09 at 12:41 AM Reply With Quote
Whats the best crushtube to polybush grease?
I've got Copper grease, Lith-Moly CV grease, and some packets of "wheel bearing" grease any of these any good for it?
James
www.warnercars.com
twybrow
posted on 5/1/09 at 12:59 AM Reply With Quote
On reccomendation from LCB, I went with copper grease for all of my suspension bolts/bushes.
cloudy
posted on 5/1/09 at 01:10 AM Reply With Quote
For the actual steel>polyurethane interface, not just for the bolts?
www.warnercars.com
Mr Whippy
posted on 5/1/09 at 07:15 AM Reply With Quote
I fitted polybushes on to my beachbuggy only for it to then start squeaking louder than the clanky engine, despite the supplier claiming that they were self lubricating. So to sort it I just used copper grease and have had no problems since and also no side effects on the bushes though they will probably last a lot longer now.
ReMan
posted on 5/1/09 at 07:29 AM Reply With Quote
copperslip for me too
the silcone grease I used during the build was dried out and sqeeking before the car hit the road
posted on 5/1/09 at 08:14 AM Reply With Quote
Yup. More copperslip for me too
cloudy
posted on 5/1/09 at 08:49 AM Reply With Quote
Copper it is
posted on 5/1/09 at 08:59 AM Reply With Quote
Ditto - squeaked all the way to and from the SVA.
Subsequently stripped and relubed with normal grease. No problems after 3k miles in all weathers/temps.
tomblyth
posted on 5/1/09 at 02:56 PM Reply With Quote
fully synthetic grease with silicon from the local push bike shop as mineral oils damage the poly bush! .. on mine are fine!
