kb58
posted on 30/1/04 at 03:50 PM |
Bosch free car handling software
I found this on the Bosch site. It's a fully functional car handling simulation. You enter all your car's data, pick a race track, and
it does it's best to calculate a lap time. Pretty cool, but you will need a lot of your car's design specs. The big unknown for me, and
which makes a big difference, is what value you put in for the tire "stick" coefficient...
Have fun.
http://www.bosch-motorsport.com/englisch/index.htm
Alan B
posted on 30/1/04 at 04:02 PM |
Hey KB....I got that last night...
Oh yeah, it was from your link on your site...
Yes, indeed it IS pretty cool...got it do a buch of stuff even before reading the manual..
alister667
posted on 31/1/04 at 12:06 AM |
Thanks for the link.
That is *some* toy! As soon as anyone gets a file of vehicle parameters for a Blade engined MK Indy punched in please let me know!!
I'm off to play with it. If I make any progress I'll let you all know.
http://members.lycos.co.uk/alister667/
alister667
posted on 3/2/04 at 08:21 PM |
I've attempted to knock up a file for an MK Indy Blade. It's a first attempt, so it's not accurate, but anyhow
http://members.lycos.co.uk/alister667/Blade MK Indy.mat" target="_blank">http://members.lycos.co.uk/alister667/Blade MK Indy.mat
sgraber
posted on 3/2/04 at 08:31 PM |
Alan,
Have you inputted anything into it for the 4AGE yet? I'd like to snag a copy of your file if available...
Graber
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
cymtriks
posted on 5/2/04 at 08:08 PM |
What's important?
According to Bosch that is.
It looks as if many of you have already had a go with this. Apart from the obvious such as engine power and weight are there any interesting things
comming out of the Bosch program?
alister667
posted on 5/2/04 at 10:26 PM |
Bosch Software
Using my Blade engined 450kg Seven setup 55% front/rear weight balance.
Around Donington GP circuit without LSD
1:43:27
with 25% LSD and 10N/mm pre-slip (?)
1:42.11
without LSD, with 10N/mm front anti-roll bar only
1:42.49
without LSD, with 10N/mm rear anti-roll bar only
1:44:21
with 25% LSD and 10N/mm pre-slip and with 10N/mm front anti-roll bar only
1:41.33
These are interesting enough, however IMHO, I wouldn't use these as a basis for running out an buying addons for the car! That said they seem
to support the obvious enough notion that if you want to go racing it would be beneficial to get an LSD a front anti-roll bar. Interesting to play
with but I wouldn't put a lot of faith in them - the model just isn't accurate enough, and I have no easy way of verifying it.
