Author: Subject: Duratec vs Zetec
andrewturner
posted on 10/1/09 at 08:38 AM Reply With Quote
Duratec vs Zetec
Is the Duratec coil pack similar to the Zetec one? I am busy installing an aftermarket ECU to a 20V Toyo and need a coilpack.
snapper
posted on 10/1/09 at 02:02 PM Reply With Quote
Any coil pack should do, i used one from a Fiesta.
I eat to survive
I drink to forget
CairB
posted on 11/1/09 at 10:45 AM Reply With Quote
I am assuming you are referring to the 2.0/2.3 Duratec.
There are at least 2 types of coil pack in the zetec with differences in the low voltage connector and the HT lead connectors.
The Duratec uses slightly different plug connectors.
Have a look in Halfords parts book as I remember that it lists the parts for the Zetec and Duratec versions.
Having said that I am using an earlier one from a Zetec, but I had to sort the leads as specials.
I have a pukka Duratec version but have not got round to fitting it yet.
This site mentions the 2 types:
http://trigger-wheels.com/store/index1.html
Colin
[Edited on 11/1/09 by CairB]
