jos
posted on 12/1/09 at 08:48 PM |
Sierra brake bias valve
I'm thinking of removing this from my braking system. Its from a sierra
Anybody got anything to say either for or against this?? or any advice??
matt_claydon
posted on 12/1/09 at 08:59 PM |
Remove it, it's useless in a seven as it works on a combination of front-end dive and vehicle deceleration to work. The valve will be calibrated
to the sierra suspension and weight distribution.
Just make sure the fronts still lock up before the rears else you'll be driving a death-trap.
[Edited on 12/1/09 by matt_claydon]
bigrich
posted on 12/1/09 at 09:04 PM |
Should be fine without it Jos, I did the same on my old orange car without any issues
JohnN
posted on 12/1/09 at 09:05 PM |
Why do you want to remove it (since you must have had a reason for installing it in the first place).
What has changed, or what do you propose to do to compensate for its loss (assuming that it functioned as intended)
tegwin
posted on 12/1/09 at 09:10 PM |
As above..
I fitted standard sierra MC, front disks and rear disks with no balance valve thing..
Passed the wicked test without any issues
www.verticalhorizonsmedia.tv
jos
posted on 12/1/09 at 09:58 PM |
My father thinks that it is causing the rear drums to drag as the car is quite difficult to push (out of gear)
We're on a mission to reduce rolling resistance (no jokes please worx, Pintos are the business) and he thinks its the bias valve
t16turbotone
posted on 12/1/09 at 10:07 PM |
fit valve from uno or punto ...works great
Dusty
posted on 13/1/09 at 03:35 AM |
Jack it up. Turn wheels individually to find if there is excess drag in one. Also check front wheel toe which can cause drag.
posted on 13/1/09 at 08:50 AM |
(1) It isn't causing the drag unless you have fitted it sloping the wrong way. -- it is a "G" valve all that is inside is a ball
bearing that rolls up a slope under breaking.
(2) This type of valve isn't really suitable for your car.
(3) The brake drag is most likely caused by either the master cylinder piston not being fully released or mall adjustment of the handbrake & brake
self adjusters.
First ting to do is check the brake pedal has a return spring and is being pulled back fully.
[Edited on 13/1/09 by britishtrident]
jos
posted on 13/1/09 at 01:58 PM |
Front wheel toe is setup correctly - done by a local trusted garage.
Brake pedal's ok. Personally I suspect the autoadjusters in the drums but we'll see
