Author: Subject: Wanted - Clutch arm for Blade 919
McLannahan
posted on 18/1/09 at 08:09 PM Reply With Quote
In an attempt to get a decent bite point and travel, I need to lengthen my clutch arm.
Does anyone have a clutch arm for a Honda Fireblade 919 please?
Many thanks
Michael
mark chandler
posted on 18/1/09 at 09:19 PM Reply With Quote
Not so sure that's a good idea as the associated brackets will need remaking, its all nice and strong as is, nothing bespoke so easier to fix in the future.
Better to move the pivot point on the clutch pedal closer to the cable end or lower the cable on the pedal IMHO, fix the end that's wrong.
Regards Mark
[Edited on 18/1/09 by mark chandler]
McLannahan
posted on 18/1/09 at 09:39 PM Reply With Quote
Thanks Mark- I could lower the cable with a bit of work but I'm not sure that'd give me enough travel still?
Thanks again
Michael
mark chandler
posted on 18/1/09 at 10:01 PM Reply With Quote
I made my pedals so cannot comment on your setup, however I get full travel with quite a wide bite area, made a long time ago but from distant memory 3/4" from centre of pivot to cable end.
Engine side is standard, pedal is so light you can push easily with your hand. Picture is when in an embryonic state
McLannahan
posted on 18/1/09 at 10:04 PM Reply With Quote
Thanks Mark. I have about an inch now from the cable (mounted at the top of the pedal) to the pivot below. Could move it down that inch but didn't think it'd make enough of a difference?
Thought that the clutch arm end might be an easier job to modify but fully appreciate what you mean about bespoke parts!
Thanks again
mark chandler
posted on 18/1/09 at 10:26 PM Reply With Quote
A little tweek here will make a lot of difference, you'll be surprised!
Steve Hignett
posted on 18/1/09 at 10:49 PM Reply With Quote
I agree - that it would be better to move it at the pedal side for throw and leverage, but it's not the moving it on the pedal that is the problem - the cable enters the bespoke pedal box (that is just ali sheet) on a bracket that is welded onto a bulkhead (of sorts) and the angle it sits on and no room below it, is the reason why it would be a PITA to move it on the pedal...
I think if the clutch actuating arm was modified, the bracket could be twisted slightly and that would sort it in no time and quite simply?
[Edited on 18/1/09 by Steve Hignett]
bigfoot4616
posted on 19/1/09 at 07:05 PM Reply With Quote
pretty much whats been done to mine, seems to work ok.
McLannahan
posted on 19/1/09 at 09:13 PM Reply With Quote
Bigfoot - How did you modify your clutch arm?
Thanks for the reply
Michael
bigfoot4616
posted on 19/1/09 at 11:40 PM Reply With Quote
i didn't, was like it when i got the car.
it is basically just a bit of metal bolted onto the arm to make it longer.
i keep meaning to have a closer look and see if i can do it a bit better as it looks a bit crap.
i can get a pic of it later in the week if thats any help
McLannahan
posted on 20/1/09 at 10:49 PM Reply With Quote
BF - That'd be great, yes please!
gixermark
posted on 22/1/09 at 10:13 AM Reply With Quote
call andy at ab performance
he can modify a std one along with the bracket to suit... all done reday to fit.
