Author: Subject: Alternator Connector
Jos Fury
posted on 19/1/09 at 10:32 AM Reply With Quote
I am looking for the (original) connector to my alternator. Is is a nippon denso unit. Unfortunately I have no serial or part number. Have tried several suppliers but no results so far.
Jos
posted on 19/1/09 at 10:42 AM Reply With Quote
Presume you've tried Premier Wiring and Vehicle Wiring Products?
Failing that it might be worth a poke around a breakers yard to see if you can cut a section out of a tin top loom...?
That's what I did for most of the OE plugs in my loom.
Mr Whippy
posted on 19/1/09 at 10:54 AM Reply With Quote
tbh what you have done is what I usually do as original connectors often become lose fitting and start over heating. Personally I'd leave it as is as I think its better and they only fit the connector in the factory for production speed rather than it being a better in practice.
[Edited on 19/1/09 by Mr Whippy]
Jos Fury
posted on 20/1/09 at 09:31 AM Reply With Quote
Will try another scrappy than. ( Tried 2 of them already )
Thanks for you advice too Mr.Whippy. Always thougt the OEM connectors where a better fit. I am a bit afraid one of my connections will loosen and shortcircuit things ...
cliftyhanger
posted on 24/1/09 at 07:29 AM Reply With Quote
http://www.simtekuk.co.uk/www.simtekuk.co.uk/info.php?p=1&pno=0
I have the same alternator (still sat in the garage) and found the simtekuk site a while ago, but hanve never got round to contacting them to check sizes...
Jos Fury
posted on 24/1/09 at 11:32 AM Reply With Quote
thank you for the link cliftyhanger. have added it to my favorites !
will receive the oem connector next week through a friend of mine who works for a toyota dealer nearby.
