Author: Subject: 3.14 Diff to LSD
cosworthspeed10
posted on 27/1/09 at 07:55 PM Reply With Quote
3.14 Diff to LSD
Is it possible to convert my 3.14 diff to LSD?
If so what do I need to buy?
Cheers Guys
mcerd1
posted on 27/1/09 at 08:06 PM Reply With Quote
yes
and you would need either an aftermarket one like quaife etc
or a 7" ford LSD with any ratio (probably from a 4x4 sierra / cossie)
this would mean using bolt on CV's (at least at the diff end)
+ seals (and bearings) to rebuild the diff(s)
[Edited on 27/1/09 by mcerd1]
cosworthspeed10
posted on 27/1/09 at 08:14 PM Reply With Quote
Ok, so I can use the ratio and put it into a 3.62lsd diff
hobbsy
posted on 29/1/09 at 03:20 AM Reply With Quote
Also if you've got a bit more to spend and want even more grip then check out my Quaife ATB group buy, look in the "Bargains Elsewhere" forum or do a search on my username (too tired to post a link...)
Bob C
posted on 29/1/09 at 12:29 PM Reply With Quote
I had a 3.14 open diff & put an ATB into it - relatively easy job, the setup stays right if you don't move the propshaft pinion - you only have to adjust the backlash & preload using the castellated adjusters.
