New Topic New Reply
Author: Subject: locking rear camber adjuster nut?
Bluemoon
posted on 30/1/09 at 11:44 AM Reply With Quote
About to set the rear camber, but what methods have people used to lock the half nuts... I don't fancy them coming loose..
Dan
Mr Whippy
posted on 30/1/09 at 11:45 AM Reply With Quote
you lock the nuts by tightening one against the other
posted on 30/1/09 at 11:48 AM Reply With Quote
lock a pair of half nuts on the inside of the wishbone and then tighten the 3rd nut to clamp the adjuster to the wishbone.
For ease of checking (before each drive) you can add a line of paint across each nut and the wishbone (once tight). This give s avery quick visual check to see if anything has moved.
Mr Whippy
posted on 30/1/09 at 12:30 PM Reply With Quote
I did this after a large and important bolt fell off my old motorbike while on the dual carriageway You know that feeling when the hairs stand up on the back of your neck...
Smartripper
posted on 30/1/09 at 12:35 PM Reply With Quote
Hello,
By my Indy when it was setup the right way. I just rolpinned the last nut...
after comming undone two times !!!???
Daniel
MikeCapon
posted on 30/1/09 at 01:13 PM Reply With Quote
Loctite (green) or lockwire?
Bluemoon
posted on 30/1/09 at 01:57 PM Reply With Quote
Smartripper How did you manage to drill the hole though nut and bolt bit??
Mr Whippy, thanks I realized that, but I would like a backup, it seems that quite a few people have them come lose.. I guess the large pitch of the thread does not help with getting them to lock.
Dan
pewe
posted on 30/1/09 at 03:14 PM Reply With Quote
Easy way of marking nuts, bolts and joins is to use one of those Snopake correcting pens.
Buy them at Staples etc.
Ink covers almost everything and sticks like nothing else.
Cheers, Pewe
Smartripper
posted on 30/1/09 at 04:02 PM Reply With Quote
Hello,
First i drilled the nut on a flat side,
jammed the nut on the adjuster and drilled just 5 mm deep in the tread, and put a rollpin in it.
I've i do it again then maybe lockwire is the way to go..
Daniel
MautoK
posted on 1/2/09 at 12:05 AM Reply With Quote
I made a couple of double-tab washers; one tab is bent over a flat of the inner nut, the other over the outer nut.
idl1975
posted on 4/2/09 at 11:24 AM Reply With Quote
Rear axle nut?
Just to second the sentiment that something should be done other than relying on the half nuts. Mine fell off a couple days ago - not very safe.
New Topic New Reply
