Author: Subject: rv8 heads. what to do???
Z20let Corsa
posted on 3/3/09 at 08:59 PM Reply With Quote
well ive removed the heads off the v8 tonight to renew the head gaskets and i need to send atleast 1 away to get a snapped inlet manifold bolt out. the question is. while there off do i get both heads ported, polished and skimmed to get slightly higher compression or not?? what sort of gains am i looking at and how much is the going rate?? ive never had this sort of thing to do before!!!
locost +4 v8 in progress.
mr henderson
posted on 3/3/09 at 09:09 PM Reply With Quote
There's a book on the RV8 written by David Hardcastle, published by Haynes. It''s very good. You should read it before deciding.
I had a copy years ago when I was involved with TR7V8s. I don't have it anymore I'm afraid.
I'm not sure that doing the heads is cost effective. You should certainly have them checked for flatness though
John
DanP
posted on 4/3/09 at 12:43 AM Reply With Quote
Be careful with skimming as you can end up with the inlet manifold not fitting until you fit a thicker headgasket (pushing the comp back down!)
Porting and polishing is not cheap, you are probably looking at 300 quid for even stage 1 heads which prob won't even include much porting.
There are some easier and popular improvements you can make like fitting bullet valve guides and waisted stem valves (they have a narrower stem section so air can flow round more easily)
You could also try a bit of a polish job yourself to clean up the tracts, the company 'standard abrasives' do an excellent porting/polishing PDF online guide.
HTH
Dan
wilkingj
posted on 4/3/09 at 11:57 AM Reply With Quote
What to do?... Easy... If you have limitless supply of Cash
Linky
Best Regards
Geoff
http://www.v8viento.co.uk
Fred W B
posted on 4/3/09 at 07:25 PM Reply With Quote
bullet valve guides
nrv87
nrv87
Few more pics in this thread
HERE
Fred W B
[Edited on 4/3/09 by Fred W B]
