New Topic New Reply
Author: Subject: Tricky hole enlargement in dashboard.
posted on 9/3/09 at 12:43 PM Reply With Quote
My dashboard has a hole where a push-button used to be; it's about 20mm in diameter.
I now want to fit a different button, but it will need to have a recess of around 25mm diameter, 5mm deep, around the original hole.
Can anyone suggest a way of cutting this recess?
matt_claydon
posted on 9/3/09 at 12:44 PM Reply With Quote
What is the dash made of and how thick is it?
posted on 9/3/09 at 12:52 PM Reply With Quote
Oops!
Marine ply, around 12mm thick.
[Edited on 9/3/09 by David Jenkins]
IDONTBELEIVEIT
posted on 9/3/09 at 12:53 PM Reply With Quote
maybe a router with 25dia plunge bit
Are We There Yet, Are We There Yet!!!!
Paul TigerB6
posted on 9/3/09 at 12:55 PM Reply With Quote
25mm flat wood drill bit?? Might need to glue a piece of wood to the rear of the dash temporarily to allow the wood drill to centre on that.
link
jlparsons
posted on 9/3/09 at 12:59 PM Reply With Quote
Draw it up and dremel it if I were you. Score the line through the first ply with a stanley knife so it doesn't splinter, then use a fine router-type bit.
Caveat - only if you have a steady hand mind! If not, go with the above.
Moorron
posted on 9/3/09 at 01:12 PM Reply With Quote
cone cutter drill bit?
file?
Sorry about my spelling, im an engineer and only work in numbers.
adithorp
I'd glue a bit of wood accross the back of the hole. Drill a centre in that and then use a 25mm hole-saw and prise the piece off after. Dremel would be second choice because it needs a steady hand.
adrian
http://jpsc.org.uk/forum/
matt_claydon
posted on 9/3/09 at 01:37 PM Reply With Quote
I think the quickest and easiset way is to glue a piece of wood on the back to hold the tip and use a (nice sharp!) flat wood bit or holesaw.
posted on 9/3/09 at 01:58 PM Reply With Quote
I'm thinking of changing my mind... I might drill right through (rather than creating a step) and then mount a plate behind the hole. The button's shroud can then fit through the dash, rather than sit on the surface.
I'll probably use an amalgam of the ideas you've all posted - I'll turn a wooden plug to fit in the existing hole, then use that to locate a flat bit.
Thanks to all,
(now go and answer my question in Electrical re. starter solenoid current! )
neilj37
posted on 9/3/09 at 02:26 PM Reply With Quote
I would have just clamped a second piece of wood to the back and used that to centre a hole saw.
cjtheman
posted on 9/3/09 at 05:02 PM Reply With Quote
second the cone cutter (step drill )
will work every time
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
Mix
posted on 9/3/09 at 05:03 PM Reply With Quote
Hi
If you want to maintain the step then use a bearing guided router bit, the finish will be as good as your original hole.
Regards Mick
New Topic New Reply
