clutch_kick
posted on 9/3/09 at 04:54 PM |
F20C Engine - Is the dash required ... ?
As the title says. Do I need the OEM Dash display to run the engine on a stock ECU, with stock ignition barrel and keys (for imobiliser)?
PAUL FISHER
posted on 9/3/09 at 07:16 PM |
It might be worth sending a U2U to Chris Mason on here,he used the S2000 engine in his Indy,but my understanding of them,I believe most people fit a
aftermarket ECU such as the Hondata Kpro,to bypass the imobiliser and all the other sensors to the ECU,it also makes tuning simple,you can bring the
vtec in sooner etc.
rickys2000
posted on 9/3/09 at 08:02 PM |
It makes life an awful lot easier to run the stock dash with the stock ECU. Do you intend to use the stock loom as well or get a modified one made up.
We have gone down the route of using the EFI Technology Euro 1 ECU and Koso dash and a bespoke loom, that after a bit of messing around with the stock
F20C crank and cam pulse wheels have got a solution that looks so far pretty good
clutch_kick
posted on 9/3/09 at 10:02 PM |
I want to use the Stock ECU and the Racetechnology Dash2 display. I need the stock ECU to have all the emissions bits running properly to get it
through our 'SVA'. Once I get used to the car and it's power, then i'll go down the AEM route.
So yeah I'll be using the Stock loom, and the engine I might be getting has got the keys and the stock ignition barrel on.
pwl
posted on 9/3/09 at 10:09 PM |
If you don’t have the S2000 service manual, go to www.hondahookup.com, register as a user and download the service manual. You can see the gauge
diagram on page 900-906, you will se that it properly is possible, but if you are using the stock wire harness it is going to be very hard.
There is a local guy here that is selling a S2000 gauge, he is selling it for circa 135 euro.
PWL
clutch_kick
posted on 10/3/09 at 03:58 PM |
Thanks pwl. Yes I have the service manual for the S2000. I just wanted to know if the ECU would have any issues without the dash connected.
mr henderson
posted on 10/3/09 at 06:19 PM |
My guess is yes, it would. I have no information specific to the Honda, but have looked at other car and bike scenarios. In most cases, if you want to
use the standard ecu then you will struggle if you don't use the standard dash (and maybe even if you do).
John
