tegwin
posted on 9/3/09 at 10:41 PM |
Do sidelights have to work with Igg off?
As the question really...
Do sidelights have to work with the ignition off?
I might possibly have wired the ones in the TVR so they only work with the ignition on..... The hazards work ok though!
www.verticalhorizonsmedia.tv
blakep82
posted on 9/3/09 at 10:43 PM |
i think they do, like parking lights
________________________
tegwin
posted on 9/3/09 at 10:53 PM |
Ok... so if the sidelights have to work with the ignition off...
Are the headlights allowed to work with the ignition off as well? (I know its a bad idea, but hey ho...)
mediabloke
posted on 9/3/09 at 10:57 PM |
Mine do. Conversely IIRC, the headlights are switched off on the current Fords when the key's removed, leaving only the sidelights...
Or maybe the Southern Comfort's numbing my brain...?
[Edited on 9/3/09 by mediabloke]
blakep82
posted on 9/3/09 at 11:00 PM |
on my E36 BMW (and my E30), and my dads vauxhall omega if you leave headlights on and turn the ignition off, the headlights go off and sidelights stay
on. its how i plan to wire mine up
jollygreengiant
posted on 9/3/09 at 11:01 PM |
Yes side lights DO have to work with the ignition OFF. If not for SVA then a must for MOT. They will not care a jot if the headlight still work with
the ignition off, but you will look very silly the day you find a flat battery, because you left the headlights on.
blakep82
posted on 9/3/09 at 11:18 PM |
wonder how you'd make a buzzer that goes off when the key switch is turned off but the lights are on?
Simon
posted on 9/3/09 at 11:28 PM |
My headlights and sidelights both work without the key in ignition.
Simon
posted on 10/3/09 at 12:07 AM |
The parking lights a re wired up to permanent live - no relay.
The headlight relay is wired to switched (Ignition) live.
Hence - sidelights can be turned on at any time. Headlights only with Ignition.
A buzzer can be wired by fitting it to the sidelight and a earthing through the door switch - now all you need is a door...
Findlay234
posted on 10/3/09 at 08:45 AM |
Is this a requirement for SVA or MOT at all?. All my bravo lights (except hazards) go off when you turn off the ignition! I like it that way so you
never have to worry if youve left your lights on.....
loggyboy
posted on 10/3/09 at 11:29 AM |
Some ignition barrels have a switched earth when turned off (I know most vaushalls do anyway) , this could be wired in to the make a lights buzzer
work.
Mistral Motorsport
posted on 10/3/09 at 07:40 PM |
Most Fiats have an extra position on the ignition switch to turn on the "position " lights when the key is removed.
