v8kid
posted on 15/3/09 at 06:07 PM |
Wtd Sierra LH Thread Nut for driveshaft
Any ideas where to get one? When removing the driveshafts from the donor I had to cut the old one off it was 41mm acoss flats and was a nylock nut
with left hand threads (the opposite way round from usual)
Paul (Notts)
posted on 15/3/09 at 06:12 PM |
http://www.westfield-sportscars.co.uk/shop/prodtype.asp?PT_ID=71&numRecordPosition=11&ph=&strKeywords=&&strSearchCriteria=
not the cheepest source but a start
[Edited on 15/3/09 by Paul (Notts)]
link now works
fairly sure it will have to be off a sierra, i think bolt suppliers would struggle with such an unusual nut. Try a post on the FSOC forum, someone
definately has one on there, failing that your local scrappers.
Paul TigerB6
posted on 15/3/09 at 06:32 PM |
Give your local Ford dealer a call - they should be able to get them in easily enough and no doubt cheaper than you might think.
v8kid
posted on 15/3/09 at 06:39 PM |
Ta I'll try ford dealer. Thanks for the westfield link lots of interesting stuff there!
mgmiller
posted on 15/3/09 at 06:53 PM |
If your are going to replace the rear bearing, the nut comes with the kit.
flak monkey
posted on 15/3/09 at 06:58 PM |
Yep, ford sell them. Think they are a couple of quid each.
Sera
http://www.motosera.com
James
posted on 15/3/09 at 07:34 PM |
Mk had them when I was last up there... about 3 years ago!
But they might still.
HTH,
James
- Muhammad Ali
Micael
posted on 25/4/09 at 08:27 AM |
I have one
You can have it (if you pay for the shipping)
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
Worzey
posted on 25/4/09 at 10:31 AM |
I need one as well. Group buy?
Just been to the local Ford dealer who initially refused to look it up on the parts computer unless I gave him a number plate or chassis number.
(It's a Q plate).
Finally convinced him to look it up and he then claimed they couldn't get them anymore. I'm sure it was because he couldn't be
ar$ed.
I've reused the old one which is far from ideal until I can source another.
Caterham R400
