New Topic New Reply
Author: Subject: Is this worth £60?
speedyxjs
posted on 18/3/09 at 06:26 PM Reply With Quote
Is this worth £60?
Hopefully thi s link works. I asked for a price by email and he sys £60. Do you guys think its worth that?
hellbent345
posted on 18/3/09 at 06:27 PM Reply With Quote
cant see it, one needs to be a member
blakep82
nope doesn't work. what is it?
________________________
Omni
posted on 18/3/09 at 06:28 PM Reply With Quote
Doesn't work. Need to be registered
speedyxjs
posted on 18/3/09 at 06:33 PM Reply With Quote
From the site
I have designed a new crank sensor bracket for AJ16 engines which
effectively increases the ignition timing by 5degrees under all
conditions. I have fitted this bracket to both my manual XJR6 cars.
Last weekend I measured some in-gear vehicle acceleration timings
using a laptop PC to log the vehicle speed signal from the
diagnostic plug using scan tool software. Below are the results of
my measurements. In each case the first figure is the time in
seconds to do the 20mph increment running std ignition timing and
95RON fuel. The second time is running with the extra 5degrees
ignition advance and 99RON fuel. If anyone wants any more
inofrmation about my bracket, please feel free to email me
directly. I think the results speak for themselves in terms of
demonstrating the performance benefit of this modification. It also
improves fuel economy by nearly 2mpg (imperial) so saves money too.
The bracket only took a few minutes to fit to my engine and could
be used on naturally aspirated versions of AJ16 engines too, in
X300 or XJS.
Gear 5th 4th 3rd 2nd
Gearing 30.1 23 16.4 11.3 mph/1000rpm
10-30
20-40 9.7 / 9.7 5.8 / 5.5 3.5 / 3.4 2.2 / 2.0
30-50 8.9 / 8.5 5.5 / 5.2 3.5 / 3.4 2.3 / 2.0
40-60 8.9 / 8.5 5.5 / 5.0 3.5 / 3.1 2.4 / 2.3
50-70 9.0 / 8.2 5.4 / 4.6 3.2 / 3.1
[Edited on 18-3-09 by speedyxjs]
dinosaurjuice
posted on 18/3/09 at 06:36 PM Reply With Quote
Originally posted by speedyxjs
From the site
conditions.
£60 for a peice of angle-iron? just no.
blakep82
posted on 18/3/09 at 06:48 PM Reply With Quote
ha ha ha er, no
stevebubs
posted on 18/3/09 at 06:58 PM Reply With Quote
may as well fit megajolt and not fit and fart around with std ign..
r1_pete
posted on 18/3/09 at 07:35 PM Reply With Quote
Just make your own mod to move the sensor round the crank by 6 degs.
MikeR
posted on 18/3/09 at 07:48 PM Reply With Quote
for a proper test - get him to do it again using just either 95 or 99 ron petrol!
If its using a crank sensor, its probably electronic ignition. If its electronic ignition there is a good chance (with it being an expensive engine) that its got a decent knock sensor and will adjust the timing as needed automatically!
steve m
posted on 18/3/09 at 07:49 PM Reply With Quote
Interesting !
Does any one know how to do somthing similar with a k series ???
ooppps that dose not have a knock sensor
steve
[Edited on 18/3/09 by steve m]
posted on 18/3/09 at 08:09 PM Reply With Quote
its as unscientific a test as he could possibly do, very unscrupulous, and im sure he knows its not scientific. The extra poke could be entirely from the different fuel, and nothing to do with his bracket.
To be accurate, he should do 4 runs, with and without both (angle and fuel change), then he could categorically prove that his bracket maximises the effect.
Paul TigerB6
posted on 18/3/09 at 08:20 PM Reply With Quote
No way would i want to advance my ignition timing by 5 degrees over what Jaguar spent millions of pounds working out. Ask the guy for a picture of his pistons in a year's time and then see if you fancy giving him £60. If he gave me £60 i wouldnt fit his bracket!!
mark chandler
posted on 18/3/09 at 08:34 PM Reply With Quote
As the car is designed to run on 95 ron then a bit more advance should help, but £60 for a bracket..... no way.
westf27
posted on 18/3/09 at 09:27 PM Reply With Quote
Buy one,paint yourself pale yellow,copy it and sell them on Ebay
555
speedyxjs
posted on 19/3/09 at 07:19 AM Reply With Quote
I get alot of advice from there as i do here and i could see it turning ugly
filiperosa
posted on 24/3/09 at 03:34 PM Reply With Quote
too expensive
New Topic New Reply
