t16turbotone
posted on 19/3/09 at 11:04 AM |
ford ctx auto box??
hello my GF has a fiesta auto 1.25 zetec, its started to stall when engaging drive, any auto guru that could help, dont even know how to check oil
level??
thanx
Ketchup
posted on 19/3/09 at 12:46 PM |
what year is the fiesta? the newer ones are fitted with a manual box thats covered in actuators to select gears and operate the clutch.. the clutch is
adjustable via eobd, starting to see a few of these coming through the doors now mith similar problems, an adjustment normally sorts it
duh, you say ctx! i must learn to read! if it mainly does it from cold and not so much from warm, there was a well known prob with a sticking valve in
the gearbox, you may need to see a specialist as they are quite complex
[Edited on 19/3/09 by Ketchup]
