scutter
posted on 20/3/09 at 04:49 PM |
Securing laptop
Just had a thought about securing my laptop whilst on track. I'd like get some MS logging at the upper end of the rev range.
Any ideas before 4am tomorrow as that's when i'm setting off?
Cheers Dan.
twybrow
posted on 20/3/09 at 04:56 PM |
Sticky backed Velcro on the laptop and the passenger footwell? It holds very well if the surface is clean and flat...
posted on 20/3/09 at 05:09 PM |
I'd agree with that - it'll take some right hammer though - the vibrations are incredible. Alternatively place it into a suspended bag to
damplen the vibrations.
I wouldn't personally but it's your call...
JUD
posted on 20/3/09 at 05:20 PM |
Don't worry Dan, you won't be going that quick.
I'll get my coat
MK Indy Blade
Keith Weiland
posted on 20/3/09 at 06:39 PM |
If you are worried about vibration just get a solid state hard drive. 30gb ones start at about £90
pewe
posted on 20/3/09 at 06:46 PM |
Dan have a great day - don't forget the sun-cream!
Last weekend at Goodwood they were adamant no loose object in the car (including Hand-held cameras).
At this late stage can you not join lots of zip-ties together and secure it criss-cross to the floor on some foam?
Cheers, Pewe
scutter
posted on 20/3/09 at 08:21 PM |
Martin Bog off. I was thinking of securing it in a rucksack weaved into the passenger harness.
I won't be using it in the first session, i want to see how close i've got on the road.
See you in the morning Mart.
ATB Dan.
paulf
posted on 20/3/09 at 10:59 PM |
To late for now but I use a palm PDA, it is small and light and is not damaged by vibration.You can fit to the dash with velcro and also use it as a
readout of engine variables.
There is a section on the megasquirt site dealing with there use.
Paul.
flak monkey
posted on 21/3/09 at 08:42 AM |
I usually get a passenger to hang on to mine
Sera
http://www.motosera.com
scutter
posted on 22/3/09 at 11:35 AM |
I got Conrod to hold the laptop once I was happy lapping the track, very helpful to tune the above 5500rpm range.
Time to look into the Pda route.
ATB Dan.
scutter
posted on 22/3/09 at 03:08 PM |
Ok I give up, does anyone have a link showing the basics?
ATB Dan.
Staple balls
posted on 22/3/09 at 03:28 PM |
If I was trying to run a laptop in that sort of situation, I'd make some kind of shock cord harness for it (I'll doodle something if you
want). It'd (probably) dampen the shocks enough to avoid damage/hdd problems, but allow some movement to avoid it shaking to death.
Also, replacing the HDD with an SSD, and gaffer taping the battery in might be sensible.
scutter
posted on 22/3/09 at 03:45 PM |
Sorry should have said, Basics about using a PDA, I can't imagine the trackday organiser liking a laptop swinging about in the passenger
compartment, they were pretty sharp about having windows done up to stop anyones arms flaying about if it nasty.
ATB Dan.
Staple balls
posted on 22/3/09 at 03:47 PM |
Ahh, that's no fun, do they have no sense of adventure?
scutter
posted on 22/3/09 at 03:48 PM |
paulf
posted on 22/3/09 at 09:48 PM |
Dan
Go onto the main megasquirt site , scroll down the discussion forums and there is one for Palm based software.
It will take a bit of reading to work out what you require as some palms are better than others for this purpose.I have a palm 111c with 8 meg of
memory that works well, they are less than £20 on ebay.You need to download the software and install it then confirure it to your set up.You will end
up with a dash mountable display that will log your readings and can then be down loaded to the lap top for editing with megalog etc.
There is also Palm tune which enables the fuel and spark maps to be altered on the go, i think this was originally designed to be used on motorbikes
etc and has an easy to view display that can be locked by a touch of a button so as you can pull over and modify one area of map etc.
Paul.
ATB Dan.
scutter
posted on 23/3/09 at 06:42 AM |
Cheers Paul.
ATB Dan.
