grub
posted on 20/3/09 at 10:13 PM |
english diff
hi has anyone got a 3.54 diff laid around
daniel mason
posted on 20/3/09 at 10:17 PM |
does it have to be 3.54? may have 3.62 lsd in a month or so!
24vseven
posted on 20/3/09 at 10:53 PM |
have a 4.1 or a 3.89 if there any use
twybrow
posted on 20/3/09 at 11:52 PM |
Can you mix and match like the Sierra diffs? I.e. - can you make a 3.54 lsd or am I being a total numpty (most likely)....?
AndyGT
posted on 21/3/09 at 09:19 AM |
Yeah, the bog-standard mk2 escort diffs can be mixed and matched back to the MK1 cortina. But you need to make sure the cwp is set correctly and not
set too far in or out. As with all diffs would cause whine on accelleration or lift off. Only exception is some RS diffs are not the same on mk2
escorts, I imagine on Mk1 RS's too.
Careful as wasn't the 3.54 only fitted in the mexicos and RS's?
nothing is impossible
everything is possible
twybrow
posted on 21/3/09 at 12:32 PM |
Yeah, the 3.54 is the RS diff....Just looked under my car, and mine seems to be leaking oil at the point where the propshaft joins the diff.... Any
ideas as I would think mr SVA will have an issue with that...!
24vseven
posted on 21/3/09 at 12:55 PM |
3.54 was also fitted in al mk2 1600 ghias
along with rs halfshafts as there slightly diffrent
some mexicos inc all mk1 escorts had a 3.77 diff
[Edited on 21/3/09 by 24vseven]
